Page 32 of 44
Posted: Sun Jun 29, 2014 9:29 am
by maccas
I wish i'd done that before getting mine re-plated. I know for future now lol. Glad you have it in hand pal.
Posted: Tue Jul 01, 2014 9:36 am
by mj43
Remember if you brace (weld) the barrel it will distort (amount of distortion will depend on whether barrel and brace were pre-heated before welding). The barrel (crankcase side) will need to be skimmed to get it level again. Should only require 0.1 to 0.2 mm but will put your port timing and squish out requiring a thicker base gasket to bring things back.
Posted: Tue Jul 01, 2014 10:30 am
Yes Mark is correct, the welds pull the base a small amount, so the bases do require skimming. Barrels are away again at my engineers being worked.
Posted: Thu Jul 03, 2014 11:58 am
Nothing exciting, just tidied the throttle cables up with some ferrules.
Posted: Thu Jul 03, 2014 5:00 pm
Water pump also arrived, so I've made a start on attaching the coolant hoses. Need to wait until the head arrives before I can finish this job though.
Posted: Mon Jul 07, 2014 1:57 pm
Brake hose on, exhaust fabrication scheduled for Friday
Posted: Tue Jul 08, 2014 12:56 am
by fred
hope you cut of the mount for the drain pipes ,or do you need that lug ?
Posted: Tue Jul 08, 2014 1:41 am
No I was going to ask the file to take a look at it Fred
Posted: Fri Jul 11, 2014 5:53 pm
Made a little more progress with my exhausts today, everything is really slow going at the moment.
Posted: Fri Jul 11, 2014 7:15 pm
by Binetta Steve
Ben if i woke up from a wet dream and thought exhausts! They would look like yours.
Brilliant, just as Bernie drops off the polishing, you pop up with engineering innovation.
Posted: Fri Jul 11, 2014 7:25 pm
Thanks Steve, I'm trying. The polishing will start when the engineering finishes
Posted: Fri Jul 11, 2014 10:16 pm
by Bertie_Mollie
Hi Ben,
Some fantastic quality work there Ben.
BUT the radio really caught my eye
Andrew
Luders wrote:Made a little more progress with my exhausts today, everything is really slow going at the moment.
Posted: Sat Jul 12, 2014 4:32 pm
That radio isn't mine, it might be older than me...
Posted: Sat Jul 12, 2014 6:18 pm
by Top-shaggy
That expansion chamber looks nice and tight under the bike
Posted: Sat Jul 12, 2014 9:13 pm
Those are the lomas pipes Shaun. I just stuck them on to see how it looked, as my custom pipes won't be finished until August. Just got too much else on at the moment to work on them.
