The Hybrid
- mr_bungholeo
plenty on ebay:-mr_bungholeo wrote:yep...very nice...could do with an r6 shock in that....
Another R6 Shock
Mike
- corky
- SHimmer45
Pics look great. she looks a bigt low at the back, have you fitted shorter tie bars?corky wrote:i haved one sat in my garage !!!! but should i get rid of my ohlins one for a production one?
- corky
i had ones made that where 25mm longer than the rgv ones, to make the subframe to rearwheel spindle legnth longer than the kr1 to allow for the rgv wheel...think my ohlins may be a bit shorter than std one...
kr1s project wanted
aprillia rs125 track bike
03 r6 race/trackbike
dr500 flat tracker project
Whats the length of the standard RGV tie bars? the one's I made are 186mm long which is spot on for a standard shock but my ohlins shock is longer, so I need to make some more so I'm going to try 192mm between centres
- corky
standard tie bars are 168mm between c of holes mine are 193mm i think, mmmh just bloody thought if i put the std ones on that will raise the back up wont it? knob.....
will swap them over..
you using the kr1s linkage or rgv elf?
will measure them and let you kow what they are mate, see if you want them..
kr1s project wanted
I'm using the KR suspension knuckle with a couple of spacers. Do you want to swap linkages as we seem each others size?
The standard RGV ones are way too small and give too high a ride height.
- corky
The Hybrid
Corky it was a pleasure riding with you guys on Friday at Anglesey. The Hybrid is a fantastic bit of kit with some really trick stuff. However the picture proves that I wasn,t actually inhaling your fully synthetic all Day
I will attempt to post some pictures of my pride & joy.
I want to do anglesea some time as it looks ace.
Corky: I'll PM you my address and we'll get them swapped over. they need a bit off fileing to look perfect as I made several ones to try and experiment with and I never got round to finishing the shaping.
- corky
ayeup dave...
yeh enjoyed myself playin with another two stroke sick of the big bike guys hogging the track and using their point and squirt technique. !!!
even tho i have to say i was a lot faster than you at the end of church.....
elf no worries mate will touch them up on the grinder..
kr1s project wanted
Just measured everything up and we are both wrong
Mine are !80mm BC and yours are 192mm. Guess what???? Yep yours are too short and mine too long. I think we both need to get some 186mm ones made
But atleast we now know the size we need.
