Motor temp.
DougB
Re: Motor temp.
Would 4stroke engine temp be comparable? After a couple of miles warm up, on my SV the coolant temp is 87-92C the whole time, the dash has a digital readout.
On my KR I've done about 500 miles now, riding on cold and warm days (not been hot yet, sadly) and the temp guage has been anywhere between the bottom mark and top mark in the OK range but hasn't ever gone above or below that. A few times I've found riding it hard the temp has come down the the lower end due to the cold air temp over-cooling the rad.
Don't know if any of that info helps at all, good luck sorting it.
Re: Motor temp.
no you can't compare.
the cooler a 2 stroke runs, the better.
Re: Motor temp.
I would be pulling into pitlane if my temperatures were anywhere close to what you're seeing during a race.
slashing
Re: Motor temp.
What head gaskit are you running.? I had a problem on one of mine like you have i used a pattern head gaskit .first time round.
I found were there was slight warp on the head it was blowing past. I got a kawasaki head gaskit an have had no problems since i think it helps with the black coating an they are thicker. hope this helps
geezagillard
Re: Motor temp.
Whats the main jet?
If idling around seems normal and opening up the throttle causes the high temperatures it may be its jetted too lean.
Mouser
Re: Motor temp.
I used a genuine gasket.
About the main jet, don't know, didn't have a look at it.
Thought about this too at the very beginning, but most people thought it was not very probable reason to the problem.
As described now with the new gasket I'm at 85-90° head temp.
Apparently this is "normal" for the Kr1-S, anyway I'm gonna mount the big YZF radiator.
Thanks
Mouser
Thanks
Mouser
Mouser
Re: Motor temp.
thanks bernie, gone that way too
So I finally mounted the famous big YZF 450 radiator from ebay, works perfectly, now I'm at 52-57° head temp.
Just the oil seal on the balancer still leaking...
thanks people
Mouser
thanks people
Mouser
Re: Motor temp.
glad thats sorted mouser hope you wil ride and enjoy your bike now.
cheers Jarno
cheers Jarno
Mouser
Re: Motor temp.
thanks jarno,
I will, just have to solve the problem of the oils seal of the balancer (as described in the other thread).
But I cannot find an appropriate oil seal, nor I see ho to get on hemi-circle off, apparently no one can help
, bizzarre, thought many had already changed that oil seal.
thanks
Mouser
thanks
Mouser
Re: Motor temp.
i have never changed that oilseal if the seal leaks i change the complete balance shaft ( never head a leaking seal myself but i sold some balance shafts in the past do to that problem)
Mouser
Re: Motor temp.
Yes thought of doing that too, got one from ebay, leaking even a bit more than mine
Now I have 2 leaking ones
Mouser
Mouser
Jiffi77
Re: Motor temp.
Sorry to high-jack the thread but how difficult is it to fit the YZF 450 Radiator?
Re: Motor temp.
Not difficult at all, I made some mounting brackets from sheet aluminium and got a pair of new hoses from Roose Motorsports. No fouling on the fairing at all
Re: Motor temp.
YFZ450 quad bike racer
YZF450 mx 2wheels
different rads, YFZ is the one you want
YZF450 mx 2wheels
