After years getting somewhat along
StrokerBoy
Re: After years getting somewhat along
Looks great. =D>
Yamaha RD350LC,
Suzuki GSX-R750RK & RB50 Gag.
Yamaha RD350LC,
pepsi
dougindoors
Love it nice design
1984 Kawasaki KR250A
2 Smokey and they bandit
pepsi
That looks like a quality job =D>
pepsi
Gerrit
The "E Box frame" transfers look out of place on a tandem twin, but other than that a first-rate job! One would wish that KHI had built them like this in the first place.
pepsi
I like the colors of it , nobody around here knows what it meansGerrit wrote:The "E Box frame" transfers look out of place on a tandem twin, but other than that a first-rate job! One would wish that KHI had built them like this in the first place.
paint job looks very very good =D>
paint scheme sadly is a bit of a hit and miss for me. the idea was good, but :
* the white on top of the tank does not flow over in the top fairing
* the white between the green and blue on the tank is too thin
* the blue and green on the tank are perpendicular, but not on the fairing
* the green on the fairing below "kawasaki" does not correspond with the green on the side-panels : the bottom line of it has a different angle
* the line of green at the bottom fairing has no follow-up on the rest of the bike
* the side panels are too white, looks like they are that way because that's were the number might come, but there are also yellow number boards at the back
* and at the same time the blue at the back is almost completly covered by those yellow number boards
can't help but feeling all the plastic's come from different bikes with different colour schemes
pepsi
You got me there,JanBros wrote:paint job looks very very good =D>
pepsi
StrokerBoy
Love it. The graphics and the mix of parts from other models make you wonder if it's a factory model or a special. Nicely done. =D>
Yamaha RD350LC,
Yamaha RD350LC,
pepsi
thanks I tried very very hard to make a "is that a factory Kawi?" head scratch happen. It looks better I think in person and at different angles. I guess with no formal graphic's training its the best I could do. Got a lot of headaches trying .
I do not want to make a big deal out of this, you are happy and that is all that matters
the graphics seem weird and all over the place, but they aren't.
the 2 blue triangles seem "just thrown on it" but their lines make sence : both folow the line of the green (on top and bottom) and are paralel to each other in the middle
the lines of the coloured parts folow up (fairing and rest of the bike), even if there is an interuption in between tank/side panels and fairing, and also the interuption is paralel.
the white on top of the tank is followed up in the top fairing.
if you study it, you'll see it is well thought through and all standard biks are like that : what might seem odd always corresponds with another line somewhere else
just to explain myself, I'll use the example you have given here :
pepsi
you nailed it!JanBros wrote:I do not want to make a big deal out of this, you are happy and that is all that matters![]()
