SHimmer45's KR1-S
- pablo
Must be something in the air.Another one coming back on line.
I reckon it's engine next too.If you've got a braking rolling chassis then it's the logical next step.Engine in, exhausts, electrics, carbs.Then get it sparked up.Then if everything seems ok...............Bodywork.
Did I say "logical"
I've never said that before
or done anything,anything like......
Did I say "logical"
- SHimmer45
i have a bit of a problem, going over the project as a whole and im not sure the rear wheel assembly is put together correctly.
do these look correct, as im sure the is a gap between the rear caliper arm and the hub of the wheel that shouldnt be there, any tell me if this is ok or post a pic up of theirs?
cheers
Lee
cheers
Lee
- pablo
- SHimmer45
that reminds me of the time when one of our members posted a picture on the forum of their back wheel when they thought the swingarm was bent - turns out they neglected to fit the caliper bracket between the wheel and the swing arm.
Not quite as bad as the member who thought his clutch was knackered because it wouldn't pull away when in gear - turned out they neglected to fit the chain!!
.....saying that though, last year I mended a puncture on my mountain bike, but forgot to tighten the front wheel nuts - you can guess what happended!](./images/smilies/eusa_wall.gif)
- SHimmer45
- SHimmer45
@Mike,
been posting alot less on forums these days so i would still check on new items but not actually take part
and havent really done alot to it for a while so decided to give the motor a wipe over and fit it.
be good to nip over and see your collection at some point as well
@500bernie
i will get some pics up over the weekend
@500bernie
Bikemike
- SHimmer45
- SHimmer45
- SHimmer45
