Page 5 of 5
Posted: Tue Nov 27, 2012 9:52 pm
Posted: Wed Nov 28, 2012 12:44 am
by Top-shaggy
The O rings look neat as a solution to cut out the head gasket.
The middle ring looks easy to do... But I don't fancy cutting the five sided external ring. How did you cut the outer ring groove?
You will have to let us know how it runs / compression etc?
Thanks for posting pic Luders
Posted: Wed Nov 28, 2012 5:08 am
by 2stroke
6 hour to program the CNC.
Now just hot a button and it does it perfectly.
Will keep you posted
Re: Possible 300cc conversion
Posted: Sat Dec 14, 2013 11:50 pm
by Gerrit
It's an oldish topic, but have you thought of using H1 pistons? They are available from 60-62 mm from Wiseco and Wössner, and 60-61 mm from Kawasaki. They also use 16 mm gudgeon pins, height from centreline of pin to edge of piston crown is 32 mm, dome height is 4 mm. Total skirt length is 65 mm. Hope this helps.
Of course, if you want a
really big KR tandem twin, you could use H2 pistons starting from 71 mm and up............
