did you blead it ? if not it won't workGordi wrote:Hi everyone. Just started bike (running on pre-mix) and it seems oil-pump is not working.
Yamasaki
Re: Not a good day
Re: Not a good day
You need to bleed it Gordi, there's a little screw on the side of the pump. Slacken it off and let it run for a while.JanBros wrote:did you blead it ? if not it won't workGordi wrote:Hi everyone. Just started bike (running on pre-mix) and it seems oil-pump is not working.
It take a little while to get the oil from the pump down the pipes to the reeds.
If it is knackered, here's one on eBay for 15 quid, which is a good price.
http://cgi.ebay.co.uk/KAWASAKI-KR1S-OIL ... 20adf7f89b
Re: Problems
you'll have to take the head off, clean them and at the same time, check if they are staight .Gordi wrote:Moe problems!! KIPs valves are very tight. Can be moved by hand with difficulty but motor won't move them. Please say it's something simple!!!!!
you also have to check if the upper ring on them is below the top surface off the barrel. if you have scimmed barrels that might be a problem.
And you better fit the head onto the barrels first and then barrels/head onto the crankcase. Are you using an original Kawasaki head gasket?
The other thing to look for while the head is off is the area around the holes where the KIPS valves go through the head gasket. It's been found on some of the after-market head gaskets that the slight dish in this area is faceing down when fitted in the suggested manner causing it to rub on the KIPS valve making it hard to turn. Can't see any reason these gaskets couldn't be fitted upside-down to avoid this problem.
Gordi
The usual stuff
Thanks for that, guys. Back to the workshop it is then.
Wonder what the kids look like these days??
Re: The usual stuff
Gordi
I hate this thing
Not sure at all, Charles. Don't think they will be for much longer!!
Ah, well.
Removed the head, cleaned the valves, refitted everything and the two left hand ones are free. The two on the right are still stiff despite trying everything. Will removing the barrels and fastening the head to them first actually help? If so, why? Totally baffled (frustrated, annoyed,etc) by this system!!
Valves all straight and problem just the same if valves reversed.
Ah, well.
Re: I hate this thing
Hi Gordi,
It might help: Kawasaki produced barrels that do not all have exact the same height. If you have two such 2 barrels and you first fit them onto the crankcase and then you try to fit the head you might put stress onto the valves and they might not turn freelyGordi wrote: Will removing the barrels and fastening the head to them first actually help? If so, why?
- kwackman12
As said already, make sure you use an original head gasket, & make sure the head is flat, it's a must that you fit the head to the barrels before you fit the barrels to the crankcaseGordi wrote:Not sure at all, Charles. Don't think they will be for much longer!!
Ah, well.
KR1 race bike
ZXR 400 Race Bike
Aprilia RS250
ZXR 400 Race Bike
Aprilia RS250
Gordi
Thanks, guys
Thanks to everyone for info. KIPs valves finally sorted. Special thanks to Ray the Guru for his patience getting the cables the right length. Had to be trial and error as servo not mounted in original place. Will refit both radiators tomorrow, bleed the oil pump (thanks, Charles) and fire it up. Managed to get insured today (Q plate issues) after about 3 hours on the phone so MoT just round the corner now. Anybody know a deaf MoT tester?
