Page 5 of 8
Re: Not a good day
Posted: Sun Aug 01, 2010 11:18 pm
Gordi wrote:Hi everyone. Just started bike (running on pre-mix) and it seems oil-pump is not working.
did you blead it ? if not it won't work :wink:
Posted: Mon Aug 02, 2010 7:09 am
by Charles
Hi Gordi,
are you sure the plastic gear that drives the oil pump, is ok?
Re: Not a good day
Posted: Mon Aug 02, 2010 11:15 am
You need to bleed it Gordi, there's a little screw on the side of the pump. Slacken it off and let it run for a while.
It take a little while to get the oil from the pump down the pipes to the reeds.
If it is knackered, here's one on eBay for 15 quid, which is a good price.
http://cgi.ebay.co.uk/KAWASAKI-KR1S-OIL ... 20adf7f89b
Oil pump
Posted: Tue Aug 03, 2010 5:24 am
by Gordi
Thanks again. Seems it just needed bleeding. Nice and smokey in workshop with pump going and premix in the tank!!
oil pump
Posted: Tue Aug 03, 2010 5:42 pm
by Gordi
Oil pump not working again. Time for the scrap bin. This thing just don't wanna work!!!
Problems
Posted: Thu Aug 05, 2010 5:15 am
by Gordi
Moe problems!! KIPs valves are very tight. Can be moved by hand with difficulty but motor won't move them. Please say it's something simple!!!!!
Re: Problems
Posted: Thu Aug 05, 2010 6:47 am
Gordi wrote:Moe problems!! KIPs valves are very tight. Can be moved by hand with difficulty but motor won't move them. Please say it's something simple!!!!!
you'll have to take the head off, clean them and at the same time, check if they are staight .
you also have to check if the upper ring on them is below the top surface off the barrel. if you have scimmed barrels that might be a problem.
Posted: Thu Aug 05, 2010 7:22 am
by Charles
And you better fit the head onto the barrels first and then barrels/head onto the crankcase. Are you using an original Kawasaki head gasket?
Posted: Thu Aug 05, 2010 8:37 am
by ScottaKR
The other thing to look for while the head is off is the area around the holes where the KIPS valves go through the head gasket. It's been found on some of the after-market head gaskets that the slight dish in this area is faceing down when fitted in the suggested manner causing it to rub on the KIPS valve making it hard to turn. Can't see any reason these gaskets couldn't be fitted upside-down to avoid this problem. :-k
The usual stuff
Posted: Thu Aug 05, 2010 5:10 pm
by Gordi
Thanks for that, guys. Back to the workshop it is then.
Wonder what the kids look like these days??
Re: The usual stuff
Posted: Thu Aug 05, 2010 7:19 pm
by Charles
You're sure they're still around? :mrgreen:
I hate this thing
Posted: Thu Aug 05, 2010 8:57 pm
by Gordi
Not sure at all, Charles. Don't think they will be for much longer!!
Ah, well.
Removed the head, cleaned the valves, refitted everything and the two left hand ones are free. The two on the right are still stiff despite trying everything. Will removing the barrels and fastening the head to them first actually help? If so, why? Totally baffled (frustrated, annoyed,etc) by this system!!
Valves all straight and problem just the same if valves reversed.
Re: I hate this thing
Posted: Thu Aug 05, 2010 9:29 pm
by Charles
Hi Gordi,
Gordi wrote: Will removing the barrels and fastening the head to them first actually help? If so, why?
It might help: Kawasaki produced barrels that do not all have exact the same height. If you have two such 2 barrels and you first fit them onto the crankcase and then you try to fit the head you might put stress onto the valves and they might not turn freely
Posted: Thu Aug 05, 2010 10:07 pm
by kwackman12
Gordi wrote:Not sure at all, Charles. Don't think they will be for much longer!!
Ah, well.
As said already, make sure you use an original head gasket, & make sure the head is flat, it's a must that you fit the head to the barrels before you fit the barrels to the crankcase
Thanks, guys
Posted: Sat Aug 14, 2010 8:28 pm
by Gordi
Thanks to everyone for info. KIPs valves finally sorted. Special thanks to Ray the Guru for his patience getting the cables the right length. Had to be trial and error as servo not mounted in original place. Will refit both radiators tomorrow, bleed the oil pump (thanks, Charles) and fire it up. Managed to get insured today (Q plate issues) after about 3 hours on the phone so MoT just round the corner now. Anybody know a deaf MoT tester?
