Page 5 of 6
Posted: Sun Jan 20, 2013 9:36 pm
by fred
what was the conlusion of the holes in front of the pistons,i had a weird thought of if you taper the hole then pin it with a taper pin then very gently swage it in there ?
Posted: Sun Jan 20, 2013 9:42 pm
by martin
I just drilled 4 extra holes [copying standard pistons] on my new piller drill
Posted: Sun Jan 20, 2013 10:00 pm
by fred
so the holes in front are still there ? ive been hunting around for different pistons and they have em ,but in my mind they`l lose crankcase compression (shall we start another thread on this)
Posted: Sun Jan 20, 2013 10:06 pm
fred wrote:so the holes in front are still there ? ive been hunting around for different pistons and they have em ,but in my mind they`l lose crankcase compression (shall we start another thread on this)
Might as well continue it here Fred (least I know where it is)
Bernie :D
by martin
I was going to fill the front holes. but Bernie was,nt sure that the alloy weld I use would,nt work loose, I also don't think the two small holes on the wiseco pistons would loose much power [am open to opinions]
Posted: Sun Jan 20, 2013 10:47 pm
by fred
im`e with bernie ,i dont like plastck fantastic stuff ,just another worry,metal metal no probs ,ime just being a rate bugger asking why are they there
Posted: Sun Jan 20, 2013 10:52 pm
Hi Fred,
All the 300s have them as they use Wiseco pistons.
What pistons are you using?
Bernie :D
Posted: Sun Jan 20, 2013 10:55 pm
by fred
i dont know to be truthfull ,what are the holes for ,think there the open pin type ,not the ones that wedge in sometimes
Posted: Sun Jan 20, 2013 10:59 pm
Lubrication I think Fred, the pistons are for an RGV250.
Posted: Wed Jan 23, 2013 3:54 pm
by martin
all done bernie :)
carbs completely stripped then ultrasonicly cleaned/ new pilot jets/new main jets/new n99 needles/new gaskets for tops/new gaskets on float bowls and new bolts. [just waiting for the no 4 slide, then I can connect the cables and you can collect when you are in my area.
I think your engine should sit in autosols reception Bernie
Posted: Wed Jan 23, 2013 4:24 pm
That looks lovely, nice work Martin
Posted: Wed Jan 23, 2013 4:30 pm
by headcoats
You need new pink hose for the carb breather pipes :mrgreen:
Yambits sell it :P
Posted: Wed Jan 23, 2013 6:00 pm
headcoats wrote:You need new pink hose for the carb breather pipes :mrgreen:
Yambits sell it :P
Hi Martin,
I got some from Allens when I was passing :D
Posted: Wed Jan 23, 2013 6:04 pm
Many thanks Martin =D>
You have done a fantastic job, I should be in your area next week.
It would still be in boxes all over the garage, if I was doing it :oops:
The drinks are on me
Bernie :D :D
Posted: Wed Jan 23, 2013 6:43 pm
by Cliff
Wow! 8)
