Thanks a few nice comments makes all the difference.... OK to answer comments, I didn't want all of the features available so I got this model but it still has lap timing / split timing / exhaust gas temp. None of which I've connected. The RPM warning lights along the top are easily set & can be split up into three different warning positions. The gear indicator in the centre top has to be set up on the road yet. The manual is 90
pages. Higher spec ones can learn different tracks & give lean angle etc etc. If you go for any one make sure It can be programed to read ( twin cyl two stroke wasted spark IGN. for RPM
I'm no expert but I believe mine thinks the engine is a single cyl 4 stroke.
Fitting it was a doddle, except the rear wheel speed pick up sensor & magnet, but someone could find an easier way than I went, + the LED's are fiddley to work with. I'm not fitting lights / indicators so only have LED's for neutral & low oil.... The flash has made this pic look harsh looks way better in the flesh.......Alan
