Page 6 of 18
Posted: Sat Jul 09, 2011 9:19 pm
by headcoats
Uploaded with ImageShack.us
Refurbed discs,they were good but a little play in bobbins,Stealth Discs will make you new bobbins at what size you need to tighten them up again
Not everyone is a fan of the bobbins with clips but Spondon used them on their brakes for years and i have had them on my Buell the last 7 years and LC 2 years
Carriers were beadblasted and Plastikote BBQ paint which is a great finish
Posted: Sat Jul 09, 2011 9:32 pm
what are the bobbins made off ?
Posted: Sat Jul 09, 2011 9:55 pm
by headcoats
Stainless
Posted: Fri Jul 15, 2011 11:19 am
by headcoats
Looks like to get front wheel central i need to remove about 2mm off the speedo drive
Do you think this is possible ?
Could mean 1mm off the drive and 1mm off the inside of the left fork leg ?
Posted: Tue Jul 26, 2011 9:43 pm
by headcoats
What do yer think :-k
Posted: Tue Jul 26, 2011 10:24 pm
looking good. you got anymore pics for us?
Posted: Tue Jul 26, 2011 10:35 pm
by headcoats
Here's the front I feel something ain't quite right :?
It is an LC frame with RGV forks and a banana arm and KR1S wheels though :lol:
I am no longer an upside down fork virgin anymore :mrgreen:
Posted: Thu Jul 28, 2011 5:30 pm
by bryan350lc
arnt you better off running the string straight to the rear tyre rather than over the yokes?
ridden my mates one Martin, must admit I dont like the lack of steering lock and its put me right off of fitting a set on my LC, leaning towards KR1S or 3MA front end and rear wheel.
Posted: Thu Jul 28, 2011 7:29 pm
by headcoats
The string over the top is a third piece so looking down you are actually ligning up 3 seperate pieces of string.
It's sorted now and put the engine in to see what offset the chain is and we got 8mm.
I know some folks have had big offset front sprockets but as on my old bike and this,anything more than 6mm and the chain will hit the inside of the frame :?
NK milled 5mm off my KR1S sprocket carrier so sprocket sat in 5mm and i had a 6mm offset front sprocket on the red LC.
So i need to decide how to split the 8mm measurment on the new one between front and rear :-k
Here's another pic,ride height is the same at the rear as my old bike and looks o.k. :P
Posted: Fri Aug 12, 2011 2:38 pm
by headcoats
Slight update,you have probably seen my ramblings about the BT92 140 tyre going out of production.
This is a big ball ache for my build as i was going to have the cush drive machined in for chain alignment but as the Bt 92 tyre (150/60/18) measures a true 158mm according to the info i was sent :shock: then this is a major f##k up :? :lol:
Only thing apart from refitting RGV wheels is to get the frame modded to bring the chain out on an offset sprocket,i had this done with the marmite #1 and got several mm in the process :-k
Posted: Sat Aug 13, 2011 7:53 pm
by headcoats
Knocked up a cardboard template to make up a bracket that will be welded to the top of the RGV swinger and bottom shock mount.
Think it needs to look a bit nicer :-k but carried along the plate so will have more welded area
The square section on the bolt will be welded to the plates at this angle
I have 8mm plate to use so should be up to the job 8-[
Posted: Sun Aug 14, 2011 12:09 am
by ScottaKR
I take it theres going to be a "left plate" to go with the "right plate". [-o< I think extending the square plate the shock bolts to down to the swinger would be a good idea as well. Then again, I aint no engineeer. :-$
Posted: Sun Aug 14, 2011 12:33 am
Have you calculated everything, so that you have the right amount of suspension-travel (or the amount you want it to be), or are you just making templates as space is available ?
Posted: Sun Aug 14, 2011 7:15 am
by headcoats
I set the ride height the same as my other bike and i have templates from other peoples bikes with the same swingarm and that is the correct height as far as i know.
Scott do you mean extending the "squareplate" which is 63mmx63mm down further to the top of the swinger so it will be a rectangular shape ?
This pic is one that has been modded,but he fitted a longer shock so is not as high as my bracket
Note this bracket doesn't extend into the shock hole of the swinger but has held fine
Posted: Sun Aug 14, 2011 12:21 pm
by ScottaKR
headcoats wrote:Scott do you mean extending the "squareplate" which is 63mmx63mm down further to the top of the swinger so it will be a rectangular shape ?
Yeah, thats what I was thinking. As you said, the other guys one has held up just fine, so it may not be necersary at all, but I'm always partial to over-engineering things just to be sure.
