KR1SV
almost a year since I posted here some news :shock:
I'm having too many problems with feeding fuel to the high presure pump, so decided to swap the injection for carbs.
Carbs and rubber manifolds arrived today and had to try them out immediatly : they are a perfect fit (allthough the injection model has slightly different heads) 8)
loom and CDI are also on there way.
Bad news to though : I'l have to redesign the bottom off the tank again ](*,)
you dont like to make things easy for yourself Jan.
smithyrc30
Post by smithyrc30 »
JanBros wrote:almost a year since I posted here some news :shock:
Jan wouldn't it be easier to use an in tank pump set up from a VFR800 or similar?
Must be loads of those in the wreckers and if you cut the flange out the VFR tank it would bolt straight in.
Might be easier than re-wiring the whole bike.
Vollegaaz
lurker
Post by Vollegaaz »
smithyrc30 wrote: Jan wouldn't it be easier to use an in tank pump set up from a VFR800 or similar?
Not a bad idea, if you like Jan, i've got a wrecked gixxer1000 tank, you could use de flange. Just ebuy a fuelpump for it.
So far my contribution.
Helloow to you all btw :mrgreen:
you need a flat horizontal spot on the bottom off the tank to use an intank pump - which a KR doesn't have . And an RGV neither -I'm using an RGV tank.
I could put it in, but since the pump won't be on the very bottom part off the tank, and it already only has about 12.5l off fuel, I won't be able to use the full capacity off the tank because the pump needs to be submerged all the time. I guess the usable capacity would be less then 10l :(
new update in the first post :wink:
smithyrc30
Looking good the Jan, glad the carbs worked out.
Question what is the upper radiator off?
You said the bottom is off a Gilera Gp50, but I could not find what the upper is.
smithyrc30 wrote:Looking good the Jan, glad the carbs worked out.
it's the top rad from a VFR400 :wink:
rad with the lowest height out there (or at least the lowest I could find ) :wink:
just realised there are no pictures off the complete bike :oops: :
more in first post :wink:
done a +500km trip today : engine runs spotless. only now I start to really apreciate this engine 8) .
but had to have some "minor" problems though :
* ran out off fuel : apparently there is something wrong with the fuel tap, because allthough it was on "on" , the fuel pump sucked the tank completly dry :? luckily just in front off a small garage :mrgreen:
* halfway the trip, I blew about 6 fuses. some after 200m, some only after 5 km. found out that if I didn't rev to high , they lasted longer. when I was down to the second last I had (used all the fuses from the lights etc) I made it to a garage and bought 30 to get home, but since leaving the garage, had no more problems, even when revving to 11.000 . looks like the loom needs a strip and thorough inspection :?
but me very happy today 8)
KwakOn
Post by KwakOn »
=D> =D> =D>
.. Image ..
I started this project in april 2005, and as off today , there is nothing more to develop/create/fabricate .... IT'S FINISHED \:D/ :D
I've been busy the last month's with lots off little things : adapting the loom so every wire has the right length, cleaning up brackets and exhaust tubes, making nicer "showable" brackets, making grill's for the radiator's, painting brackett's , .... that sort off stuff.
today I made the last bracket for the fuel pump, had to put it in another place because the fuel lines had to bend too sharp. the paint is drying now, and as off tomorrow when it's on the bike, there is nothing more to do 8) .
now just test-riding it one more season, and next winter a visit to the powdercoater and painting the plastics/fueltank
=P~
just made a calculation off how much the bike has cost me :
engine : SV650 injection model swapped for a complete motorcycle
frame : KR-1S 75
swing arm : braced KR-1S with home made suspension link
suspension rear : GSX-R 1100 Technoflex, fully adjustable with hydraulic preload 220
front suspension : CBR600RR '04 inner tubes with complete internals 66.50
front suspension : CBR900RR '92 outer tubes 52.50
triple clamp : CBR900RR '92 with home made stem 66
front fender : CB900RR '92 50
front seat : KR-1S
rear seat : adapted ZXR400
plastics rear : adapted KR-1S
front wheel : ZX6 '95
rear wheel : Bandit 400
rear brake disc + caliper + brake pump : Bandit 400
front discs : 310mm ZXR750
front brakes : Ducati 996SPS calipers+master cylindre+brake hose 140
rear tire : Pilot Power 160/60-17 as good as new 75
front tire : BT014 120/60-17 second hand 25
carburators + manifolds : SV650 carb model 129
air filters 20
CDI : SV650 carb 80
loom : SV650 carb 87
stator + rotor : SV650 84
high tension coiles + rectifier : SV650 inj 41
tubes for exhausts 100
oil cooler : ? 20.5
fuel tap : RGV250 13
fuel tank : RGV250 VJ22
top radiator : VFR400 top radiator 65
bottom radiator : Gilera Runner 50 20
fan radiator : Transalp 50
rod ends 50
brakets support the helmet 38
switches steer left : SV650 carb 22
double front headlights 93
switches steer right + throttle + throttle cablel + right front footrest : SV650 95
left front footrest + cover front sprocket + clutch cable + pillion foot rests : SV650 75
exhaust can's : Z1000 100
hoses oil cooler 20
fuel pump : ZZR1100 10
battery 80
front stop light switch Brembo 56
chain + sprocket 140
choke cables + ignition switch + part off loom : SV650 carb 85
temperature gauge + sensor : ZXR400
steer 41
rear indicators 25
digital dashboard : Acewell 100
mirror 25
grill's for radiators : home made 38
stainless steel welding wire 40
lead 65
cupper tubing for cooling system 20
stainless steel tubing for exhausts 100
aluminium +/- 175
ertalon for crash bobbins 30
TOTAL 2.977.5
if there is no price mentionned, it means I allready had those parts lying arround. the list is the money I spent on the bike, making it as it is right now. costed me about 500-600 euro's more though (buying parts I never used, or were taken off again (like injection parts , CDI, ...)
fair price, considering 99% off the bike is excactly what I want it to be 8)
=D> =D> =D> always the best thing ive seen or read on t internet ,may you have many many years enjoyment ,spot on
put the bike on a balance today : 80kg at front, 102 at the back. tank wasn't full, so add +/- 8kg, gives a total off 190kg ready to ride all full.
did the same once with my KR-1S streetfighter, and that one was 145kg.
so it's about 45kg heavier, but it doesn't feel like that (allthough I have to admitt it's been a long while since I rode my stroker :oops: ).
