2x engine build
EYREY1
Re: 2x engine build
Post by EYREY1 »
mk2 front end is on
engine is sort of back in
ally shiney ally mk2 rear subframe
Re: 2x engine build
Awesome, overtime required with the Solvol to bring that up to mirror finish : :D
It's probably the angle you have took the photos from, but what is the ground clearance at the lowest point on that bottom pot?
Re: 2x engine build
500bernie wrote: It's probably the angle you have took the photos from, but what is the ground clearance at the lowest point on that bottom pot?
a better picture on page 5 shows there is plenty :wink:
Re: 2x engine build
Cheers Jan :)
Gary when I am next passing do you want me to pop in with my Solvol, I am running out of things to polish (I only have my spare calipers to finish) #-o
After that I am going to have to get myself a new project :shock:
Re: 2x engine build
Post by pookie »
Solvol rehab for you again, Bernie :)
DougB
Re: 2x engine build
Post by DougB »
Enjoying following your build, looks brilliant, can't wait to see more of it coming together..
dirk
Re: 2x engine build
Post by dirk »
lovely project. =D>
here someone is making a similar project:
http://www.2t-special.it/forum/viewtopi ... 4&start=60
EYREY1
Re: 2x engine build
Post by EYREY1 »
thats a bike alex in italy is building for a customer
he did what he was paid to do then handed it back to he owner he had to fit he engine and make some exhausts and fit a wider rear wheel ,thats why it stopped months ago ,the owner doesnt want to posta about it
ive been in contact with him for nearly a year
another was built as a race bike in 2006 i think by someone else
and ive been in contact with a lad who did a lot of work on that one ,it has jolly moto pipes on that one
EYREY1
Re: 2x engine build
Post by EYREY1 »
did a bit more
tank and seat were just to get an idea of how it will look
dirk
Re: 2x engine build
Post by dirk »
I am afraid that you have on the right side too little cornering clearance ...
Re: 2x engine build
dirk wrote:I am afraid that you have on the right side too little cornering clearance ...
Are you calling Gary fat? :-D
Re: 2x engine build
viewtopic.php?f=8&t=12100&start=60
EYREY1
Re: 2x engine build
Post by EYREY1 »
the pipe will not touch the floor
it is going to be another 2 inch higher at the front and 30mm at the back
once its sorted , tyre on the front is just to stop rinm scratching its not blown up or wide enough
so once its coated and it gets a new tyre it will be a good bit higher ,and rear is getting 30mm jackup
ive lent bike well over and its almost got bar on the floor before pipe is ,
camera must be making it look worse than it is
Re: 2x engine build
It doesn't look that bad to me from the photos Gary
EYREY1
Re: 2x engine build
Post by EYREY1 »
Luders wrote:It doesn't look that bad to me from the photos Gary
its not bad at all , no way will it touch
