rear brake
Posted: Sat Sep 07, 2013 7:17 pm
i have had the rear wheel off today to put a new disc on, put it all together had a run, noticed the rear disc was very hot, so had a closer look, the pad that fits inside the mounting bracket was not in correct and was stuck and binding , dismantled and resembled had another look and the pad looks like its only 1mm inside the metal mounting bracket which looks unsafe so i looked at the wheel spacers (top hats) , looked on the parts fiche online and as i read it the 14mm spacer goes on the sprocket side and 11.5 mm on the disc side, mine was like this but looking at the brake pad looks so wrong, so i have now swapped the wheel spacers over so it pushes the wheel over 3 to 4 mm towards the sprocket side and now the pad fits perfectly inside the bracket and has no chance of coming out.
now i have the 11.5mm spacer on the sprocket side and it looks safe and correct
so am i reading the diagram wrong or is the fiche wrong or am i wrong
