Guess what!!!
Re: Guess what!!!
weve come to the conclusion it may be a home made add on ,did a thread get stripped and ended up like it has ,personaly ide keep it as its original
Re: Guess what!!!
My GSX will be delivered on Monday tea time
So I will post some pics if your interested.
Re: Guess what!!!
Hi Ian,
Pictures please [-o<
I had a flying banana when they first came out (GS750) the shame
I recall the GSX coming out with antidive, they were connected to the calliper with a couple of hoses. Dont remember anything looking like that. Some close ups would be very interesting.
Re: Guess what!!!
I have been doing some research and the Hot & Cold taps are standard equipment from the factory, I have never seen this before I don't think it was fitted to the UK model at least in this engineering design.
Look closely at the top set of images, it's very quirky
http://www.suzukicycles.org/GSX-series/GSX750E.shtml
Re: Guess what!!!
I have now got my GSX750ET
The engine sounds as sweet as a sewing machine, And one or two things will make you chuckle!!!
This bike has just had a 12 months MOT put on it last week!! Who did the MOT Stevie Wonder!
Re: Guess what!!!
bit of work required there, obviously the mot guy was on holiday so they got the tea lady to test it makes a change from the mot tester I went to six years ago who advised me that the front brake discs on my kr-1 were three thousandths of an inch too thin! that's less than the width of a human hair six years and a different mot tester later and the same discs are on the bike bit confused by the clocks as the speedo is in miles per hour and the odometer is in kilometres, is there a country that measures speed in miles per hour and distance in kilometres
Re: Guess what!!!
I will make a start on it come winter in the meantime do lots of reading and collecting NOS parts for it.
I have not decided whether or not to have the odd steady ride to work on it, quiet country roads to where I work so can plod around at 40/50 mph on it.
I will get the engine professionally cleaned up in one lump as it is very sweet, I will just have to make it water tight.
Re: Guess what!!!
OK I fibbed!!!!
I am not waiting until winter to start the rebuild into a shinier than a shiny thing, I am starting it on Friday and hope to be dropping the engine off in Brum mid week for Soda blasting as thats the closest place I can find to Doncaster.
I know it's not a Kawasaki lads but I think I have earned my wings so to speak to make a thread about my build and I will make it entertaining as always
WHERES THE SCOTCH!! I do my best work when I'm pissed but Norman my boss frowns on it!!! Spoil sport
Re: Guess what!!!
WHERES THE SCOTCH!! I do my best work when I'm pissed but Norman my boss frowns on it!!! Spoil sport [/quote]
you and all the other airline pilots
Re: Guess what!!!
Well the GSX is stripped to the frame, no real dramas except the wiring loom is a joke so me and my mate Rob will be making a new one later,
The cam cover breather is broken due to some ham fisted dick, and that's it so far so I'm happy.
I will post pictures tomorrow evening.
Re: Guess what!!!
Started to strip the engine down, Things started off bad by a cam bearing bolt snapping off in the head, then the little 6mm bolt at the front of the cylinder snapping too.
So they will be taken to my friend Martin at MK Engineering in Maltby to have those removed.
Then once the crankcases have been split there are a couple of little nicks that just want building up and the dressing back to shape,
Then finally take them for soda blasting.
Re: Guess what!!!
tighten before loosen - that's the key !
Re: Guess what!!!
Trust me I tried everything Ive been a mechanic 27yrs but sometimes shit happens,
Just removed the pistons and gudgeon pin retaining clip on No2 was just about to take a shit as it was half out
Re: Guess what!!!
