f3 valves
Re: f3 valves
if you change nothing else , you can only fit them on the outside on the resonator side. the ones on the inside would turn the wrong way.
It can be done though, as I've done it, but it involves a bit of work and making new pulleys and links and swapping over some electrical wires. but don't thinck you'll have a rocketship afterwards. it probably gives minor improvement, but next time it would be one of the last things on my improvement list.
http://tinypic.com/player.php?v=11qixpi ... 3k6C-7Vph4
viewtopic.php?f=19&t=7690&hilit=how+to+set+up+F3+valves
Mouser
Re: f3 valves
Hi,
Just about to fit my F3 valves.
Just to be sure the way they do fit (right/left).
Am I right that the valves come like they are in the image http://www.bdkraceeng.co.uk/Images/valv ... 1%20F3.jpg.
The open side to the outer side and the bottom of the valve opening incline upwards toward the front (hope you see what I mean.)
I fitted them switched the other way roung right/left that in the image and it maked more sense to me..
Thanks
Mouser
Thanks
Mouser
Re: f3 valves
when you look at the image, you have to remember that when you look at the 2 bigger F3 valves, you look at their front side, and that you look at the back of the cylinders.
so the valve on the right goes in the right cylinder, but turned 180°. you have to fit them so that the closed part of the valve goes on the resonator side, so it can open and close the chamber.
Mouser
Re: f3 valves
Ok, thanks JanBRos,
fits
, and works
, motor semms to have a bit more power under 5000 rpm!
Thanks
Mouser
fits
Thanks
Mouser
