Indicator Problem ???
Jiffi77
Hi, I've got a problem with the indicators on my 1991 KR1S and was hoping someone could help me solve the problem, I'll do my best to explain: Indicators work when engine is on idle - as soon as engine revs increase indicators stop working, but as soon as engine revs drop back to idle they start working again, however if I have the lights on the indicators will work when the engine revs increase. I've checked the battery voltage with engine running and this seems OK, I've changed the regulator which hasn't cured the problem, currently using a pattern relay as the original (plus spare original) failed on the bike. If anyone has any ideas it would be greatly appreciated.
Jiffi77
Re: Indicator Problem ???
Hopefully sorted now, replaced the pattern relay with a genuine one and all seems OK [-o<
