Strange Electrical Fault!
Posted: Mon Aug 04, 2014 6:33 pm
by Steely
I have discovered a strange electrical fault with my KR-1S, when you push or operate any of the handle bar switches, horn button, or any other switch, the kips motor does a cycle of opening and closing, never seen this before.
Has anybody come across this before?
Any help on this would be greatly welcomed.
Thanks in advance,
Tony
Re: Strange Electrical Fault!
Posted: Mon Aug 04, 2014 6:52 pm
I think it might be bad earth.
try again with a cable from "-" battery attached to the KIPS motor
Posted: Mon Aug 04, 2014 8:52 pm
by Steely
Hi Jan,
Tried the earth cable, no luck, just can't work it out.
Also could you help with this question, there is a 2 pole connector attached to the wiring that comes from the left hand switches, the wire colours are black & yellow & plain black, do you know what this connects to.
Thanks in advance,
Tony
Posted: Mon Aug 04, 2014 9:21 pm
The connection is for the clutch lever switch (part of the side stand safety circuit).
Posted: Tue Aug 05, 2014 2:38 pm
by Steely
Thanks for the replies guys, but the problem still exists, any more ideas greatly welcomed, as I am stumped.
Posted: Tue Aug 05, 2014 9:04 pm
by KR-1R
IS THIS WITH ENGINE RUNNING?...
... is it simply your battery is borderline flat and any item turned on triggers voltage to dip too low and kick cdi/KIPs ? give it a charge
try disconnecting the temp gauge (and clocks)
I think this has a might live +ve feed that could supply a short circuit
start eliminating factors
is it left AND right bars?
with clocks and headlight removed?
