them bleeding kr1 calipers!! (i wish)!!
Posted: Tue Apr 17, 2007 9:53 pm
by mgtkr1
having cleaned my calipers up a bit it came to fitting/bleeding them, fitting took all of half hour, bleeding, well this was 3 day ago!
are they all this reluctant because mate had same prob with same model(b2). any ideas? cheers matt
Posted: Tue Apr 17, 2007 10:03 pm
by col
they can be a bit of a pain when you completely drain the system.
i used to tap the lines and all connectors when i'd shut the bleed nipple. start from the caliper your doing and work your way up,it does make a difference.
alternatively get a bleed gun thingy, they suck the fluid into the caliper rather than squirting it in from the master cylinder.
have you done the tieing the lever to the bar trick and leeving it overnight?
that usually helps a bit.
Posted: Tue Apr 17, 2007 10:20 pm
by Red Devil 777
Or rather than a bleed gun thingy, reverse bleed them, big syringe and put brake fluid in through bleed nipple.
With the tying the brake lever back overnight one, run a pipe from bleed nipple to master cylinder, either of them normally works for me.
Posted: Wed Apr 18, 2007 10:14 pm
by mgtkr1
Posted: Thu Jul 31, 2008 4:40 pm
by Mohawk
Best to bleed them off the discs, just put something slightly wider than the disc between the pads & tape in place, then raise the caliper so the bleed nipple is at the very top. Most bleed nipples are not at the top point so make the air difficult to remove !
