gear box???
Gonzo355
gear box???
Post by Gonzo355 »
Hello i was just out for my monthly(if im lucky) ride, when while still warming up nasty noises that i thought was top end death.Anyhow not the top end,no apparent damage so took off clutch cover,nothing again.Anyhow the crank will only turn about 98 deg back and forth freely.when the crank stops it feels kinda like it should!! not like its snaggin.
There is a slight dink on the left of the crank that i think is previous.
Any insight??
Thanks martin
Re: gear box???
check the flywheel for loose/broken magnets.
check that all gears still work .
Gonzo355
Re: gear box???
Post by Gonzo355 »
gears engage ok and flywheel appears clear of bits floating about.
Is it poss the balance shaft do they ever fail??
Re: gear box???
Post by SP_BOTT »
Didn't someone have similar noises a little while ago, turned out to be inside the gearbox cover/selector area. can't remember the thread sorry.
Gonzo355
Re: gear box???
Post by Gonzo355 »
Turns out 2 be the bearing on the balancer shaft which is not apparently not a separate part No.
And the balancer is Nla .I thought the crank bearing might be a punt as looking at the Kawasaki drawing they look very similar, any thoughts?
DougB
Re: gear box???
Post by DougB »
The balance shaft can be separated and rebuilt if you know an engineer with a press nearby.. measure up the bearings and get replacements, and might as well do the oil seal at the same time.
