Gearbox failure
dirk
Gearbox failure
Post by dirk »
Hi Guys
no luck with my KR :(
while driving i could found from one moment to another no more gear. :shock:
the Neutral lamp was out, but there was no gear in it.
i had to roll out the bike.
in standing, when I press down (or up) the shift lever and I turn the rear wheel, it feels as if a gear would be in there.
but I also hear something clacking.
if I release the shift lever, the rear wheel turns freely again. as if the idle would be in there.
it is impossible to insert a gear.
has one an idea?
cheers
DougB
Re: Gearbox failure
Post by DougB »
Could be a lot of things Dirk, but I'd start by taking the gear lever off and removing the cover from the shift selector casing. Make sure everything is in place (especially the selector drum end bolt) and any return springs.
If you get in there and all seems ok, remove the gear selector assy (this is the shaft that the gear lever front knuckle clamps onto) from the selector barrel. Turn the selector barrel using a socket on the end bolt and extension bar while turning the rear wheel slowly, check it goes through all the gears and has a neutral.
Let us know how you get on, Doug.
Re: Gearbox failure
If you mean you can't select 1st or 2nd gear from neutral I have had this happen twice before
Luckily it was an easy fix
If you remove the small cover behind the gear lever (as Doug has said) - the problem each time was that
a return spring had broken
Hopefully this is all that is causing your trouble :)
dirk
Re: Gearbox failure
Post by dirk »
Hi Guys
the spring is broken.
unfortunately, the mechanism of my spare engine is different (from KR1 ?).
the spring is much shorter.
i'm a little unsure
i can very easily and widely rotate the drum.
is that normal?
http://www.divweb.com/rd/mykawa/shift_drum_kr1s.m4v
cheers
ADAC....
Re: Gearbox failure
dirk wrote: i can very easily and widely rotate the drum.
is that normal?
it all depends on the position of the sprocketts on both gearbox axes. sometimes you can go through several gears at once, sometimes you can not engage a single one.
while turning the rear wheel, you should be able to engage each gear and check that (if you turn the rear wheel) the speed of the front gearbox axe slowes down the higher the gear you engage.
dirk
Re: Gearbox failure
Post by dirk »
Thanks for the explanation Jan
what is the correct part number (long spring) for my engine?
springs are no longer available. :cry:
and now???
Re: Gearbox failure
Hi Dirk
Try Cradley kawasaki, they appear to have them in stock (check your model and frame number range, C3 UK are still available).
http://www.kawasakioriginalparts.com/ka ... 1991&ca=GB
dirk
Re: Gearbox failure
Post by dirk »
Hi Bernie
Thanks for the address .
Unfortunately NLA
fits a spring from another motorcycle ?
is my ( long ) cracked spring from the KR1S or KR1 ? :-k
cheers
Re: Gearbox failure
both springs are no longer available japan 92081-1709 92144-1448
stocks could be different in EU
many engineering shops sell partitioned boxes of extension compression tension spring assortment
you might look at side stand springs or brake pedal springs...
92081-1296 92145-0105
92144-1185
Re: Gearbox failure
it's a spring, just find one that fit's with some tension and it wil do the job.
dirk
Re: Gearbox failure
Post by dirk »
JanBros wrote:it's a spring, just find one that fit's with some tension and it wil do the job.
I've already asked in some motorcycle shops.
nothing to find.
The problem is the long hook.
Re: Gearbox failure
make your own. springs can be bent :wink:
dirk
Re: Gearbox failure
Post by dirk »
I have a spare spring.
Many thanks to Jarno! =D>
JanBros wrote:make your own. springs can be bent :wink:
Jan, i work in the IT.
should I gouge out an eye? :lol:
cheers
Re: Gearbox failure
When you fit the spring i would check that it does not rub against any moving parts
As i recall there are different ways of fitting it - and i think constant contact with the change mechanism
could have worn it through
