Rear Shock, What else fits in...
Posted: Thu May 03, 2007 11:05 am
by rc46
Ive seen some of the posts regarding a R6 Shock fitting into a KR but dose anybody know if there is anything else out there that uses the same shock OR that will slip staright in? as a KR-1s? Im looking for a cheap replacement while mines being serviced?
Posted: Thu May 03, 2007 9:12 pm
a KR1 shock is very very short, I havn't found another one that's as short
For my KR1-SV project, I'm milling another linkage part (that thing with the 3 bearrings) at the moment, so I can fit longer shocks
Posted: Thu May 03, 2007 10:31 pm
by the-elf
Just do what I did and have someone build you a one off ohlins shock
Posted: Thu May 03, 2007 10:47 pm
by rc46
Dang!
LOL
Elf, if i had one built it would double the price of the bike LOL!!!!!
maybe for the project, but for the track i rekon its best to get it serviced and or rebuilt ive had quotes from 70 - 100 quid!! which isnt too bad!
Mind you your ohlins looks trick as fudge!!!! lovely!!
Posted: Thu May 03, 2007 11:19 pm
by the-elf
It shouldn't cost much for a oil change and a re gas unless you'r going for a re-valve as well?
Posted: Fri May 04, 2007 8:38 am
by rc46
I was going to use K-Tech?
Do you know anyone else ?
Posted: Fri May 04, 2007 10:32 am
by the-elf
Russ at Mick Gardner Racing Does all of my suspension work. Give him a bell and I'm sure he'll sort you something out.
Posted: Fri May 04, 2007 10:59 am
by rc46
Aye,,,
Just did, £100 so looks to be the going rate, he's got a 2 week turn around so as soon as i wip it out (stop it!!!!
) ill send it off to russ, He said it may be bollox'ed but if it is there is no charge
is that good or bad LOL
Posted: Fri May 04, 2007 12:05 pm
by the-elf
That's why I've got a KR1S shock in piecies
It was knacked when he stripped it. He is good and honest when it comes to suspension and you can just phone him at any time for help or advise on bike set up or anything suspension related. He won't just re-gas and oil a knacked shock and charge you for it.
In the end I bite the bullet and got him to make the ohlins for me. It wasn't that much more expensive then messing about and trawlling round buying shocks and getting them stripped.
shock
Posted: Fri May 04, 2007 1:10 pm
by fenno
what year model R6 shock
Posted: Fri May 04, 2007 1:38 pm
by the-elf
info on the R6 shock is in the KR archive section.
