uneven temperatures
Posted: Sat Oct 24, 2015 4:20 pm
by skinnybob
Hello, had my motor re-built, carbs cleaned have got left side running much hotter than right, can't touch the left barrel (and it sounds uneven). Haven't warmed it up fully to set the idle as I didn't want to cause any damage. Have swapped over the leads and plugs but it's still the same. There's unburnt fuel on the right plug.
Any ideas??
Re: uneven temperatures
Posted: Sat Oct 24, 2015 7:43 pm
Hi Bob
You need to fully synchronise your carbs, making sure throttle slides are even, airscrews and tickovers are set correctly, as well as the choke plungers (and don't forget to check your oil pump after you have been messing about with the cables).
Posted: Thu Jan 07, 2016 9:00 pm
by headcoats
Is it possible to swop the carbs over to see if the problem travels to the other side
The carbs need to be totally disassembled to clean them properly and you need to take the section out that's held in by the 2 security screws
I use a small ultrasonic cleaner ,some fishing line to poke through the holes and some WD40 with a straw !
Put the red straw on the WD can and hold against the tiny holes in the carb and blast through after the ultrasonic and a poke with the nylon fishing line
Posted: Thu Jan 07, 2016 9:49 pm
by jarno
You can swap the carbs no problem,
Check the fueltap if it flows correctly
Also check the wires of the side stand switch if there properly conected.
Cheers jarno,
Posted: Sun Jan 10, 2016 10:07 am
by James P
Good advice from those who have replied so far. If you check and/or adjust all the suggested aspects and still have the trouble, consider whether there may be a different problem on each cylinder (e.g. a serious air leak or lack of coolant flow on the left and choke stuck open or blown crank seal on the right).
From your description, I presume your engine was rebuilt by someone else. What exactly did they do? Which parts were replaced and which ones are original or as before? Could you ask the engine builder's opinion on what may be causing the trouble? Let us know if you make any progress.
