back wheel ,brake disc bolt size
bsa70
Post by bsa70 » Fri Jan 15, 2016 9:51 pm
hi what I need to know is what diameter is this bolt ,is it an m8
cheers
James P
Re: back wheel ,brake disc bolt size
Post by James P » Sun Jan 17, 2016 12:42 am
If you mean Part Number 92001-1951, then yes - it is M8. The bolts for the discs are the same for front and rear wheels.
Post by 500bernie » Sun Jan 17, 2016 9:40 am
If you are using ones from another bike, make sure that the shoulder length is the same, because if is too long you will run out of threads before it nips up on the disc.
Post by KR-1R » Sun Feb 21, 2016 9:22 pm
Users browsing this forum: Bing [Bot] and 1 guest
