Does anyone know of anyone/anywhere that has the two pipes that come from the oil pump and go into the inlet rubbers? Cradeley kwak dont have them. I finally got mine running the weekend and once I had turned it off i noticed two stroke oil leaking from behind the plastic cover that covers the pump. When i removed the cover I found that the two pipes have sheared off on the eyelets where the banjos pass through.
Kwak part number is 92059-1963
Cheers Waza.
Oil pump pipe ends broken off!!!
Re: Oil pump pipe ends broken off!!!
I Also need the size and a source to replace them as I've snapped one, in the same place.
I ordered these, but they called me back to say that the
pipes are cracked.
pipes are cracked.
I think I may have some of these pipes, will try and have a look today at the workshop if I get time.
Hi Mark, I think I have sorted it now witha couple of hydraulic banjos and fittings and connected them with vacume pipe. I still have a problem with the revs hanging at about 2k. How much do you
want for them and where are you?
You wouldnt also have a spare throttle cable would you or know wher i could get one made up?
- James P
Venhill will make you one, or sell you the bits so you can make it yourself. You may also find other firms which offer similar parts and/or service.waza1972 wrote:...You wouldnt also have a spare throttle cable would you or know wher i could get one made up?
