Base / head Gaskets
- rc46
Base / head Gaskets
Do you guys install your gaskets dry? or spread some oil across the surfaces? I havent done a top end before, other gaskets on the cases ive allways coated them lightly in oil to give a good seal, but noticed that the head and base gaskets are fairly dry?
1 x TDR250 Black
1 x TDR50 Blue
1 x TZR250 3MA
1 x TZ250 3YL
1 x TZ250 N (to be restored)
1 x TD3 (being rebuilt)
1 x TDR50 Blue
1 x TZR250 3MA
1 x TZ250 3YL
HEad can be dry but the base gaskets should have a decent cement/sealant on both sides as they can pop out at the front of the cylinder.
try some hermatite blue gasket cement or if you want the good stuff get some Wellseal. Its expensive but very good.
- mr_bungholeo
rc i can send you some crank bond if u like..i'll put some in a plastic bag for ya...we use it on engine n gearbox faces that use no gasket n it works great..
similar to the stuff thats bonded onto the head gaskets....
danny harris.....R.I.P
gone but totally forgotten...
- rc46
cool as, That would be awsome! Dose it last long? I wont actually need it for a few weeks until the repair has been done, and i put the motor back together..
either way i can ping you nearer the time or if its one of these things that last's in a bag ill have some now.
By the way, i take it its just a thin layer as itll squish into the water ways etc yes?
1 x TDR250 Black
1 x TDR50 Blue
1 x TZR250 3MA
1 x TZ250 3YL
1 x TDR50 Blue
1 x TZR250 3MA
1 x TZ250 3YL
- rc46
Elf, might buy some of that as well for next time LOL well i hope next time is a schedualed rebuild.
is this it
http://cgi.ebay.co.uk/Wellseal-Gasket-J ... dZViewItem
I ask as it says it dosent harden, will this not lube the gasket and cause it to slip more? no idea never had the stuff, ?
is this it
1 x TDR250 Black
1 x TDR50 Blue
1 x TZR250 3MA
1 x TZ250 3YL
1 x TDR50 Blue
1 x TZR250 3MA
1 x TZ250 3YL
- mr_bungholeo
it does harden but turns to rubber...
forever....its like silicone sealant but a bit thicker n stains your fingers black so wear gloves!!!
its designed for bikes(bmw but the same as kawasaki bond..)so has no probs with heat,petrol,oil etc...
pm me your address n it'll b with ya by the weekend...
n yep just like that....
- mr_bungholeo
deleted dublicate post
Yep thats the stuff. Its as sticky as hell so don't get it on your hands and its not good for kids so don't force feed them the stuff . That bond stuff Mr B is on about is excellent and you don't need a gasket with it. I use the bond stuff everywhere on the engine except for base and head gaskets.
- mr_bungholeo
i use it all the time on timing covers,sumps,etc...basically on machined faces....as its factory stuff it works....cos bmw have a BIG problem with corrosion on their painted parts...so we have shed loads of the stuff...
let it cure for an hour or so before you fire her up...
- rc46
Mr B just to confirm, As i dont wana be stupid!! LOL I need the gaskets to get the right height for Head and barrels this stuff can be used along with gaskets YES? i think thats right,
But in addition it sounds like itll be good for when i put my new engines cases back together where there are no gaskets?
Cool
Cool
1 x TDR250 Black
1 x TDR50 Blue
1 x TZR250 3MA
1 x TZ250 3YL
1 x TDR50 Blue
1 x TZR250 3MA
1 x TZ250 3YL
- mr_bungholeo
