The wrong discs Grommit
Braking issues
Just got some front discs for my LC KR1S Hybrid but i don't think they are the right ones.
They are in the post at the mo,so can't measure.
They came from a 1989 ZXR 250 A
I have a feeling i got the wrong ones :?
Can a resident brake spotter please enlighten me :wink:
[img][img]http://img242.imageshack.us/img242/886/62641ws0.th.jpg[/img][/img]
Red Devil 777
Post by Red Devil 777 »
If they're zxr250a, 300mm dia they're the same as 1s discs.
And no I've still not decided what I'm doing with that seat :lol: :lol:
He did measure them for me and they are 300mm but it looked like the outer swept area was thinner as in less brake pad surface area :?
Just sell me the seat and it will be one less thing in life to think about :wink: :lol:
ZXR 250 A Discs above
KR1S discs
As you can see the discs in the lower pic have a greater surface area
I guess the ZXR discs were used on forks that should have 310mm discs fitted, or he had smaller brake pads fitted.
to me they are the same, only the ZXR discs were not used on to their "full extend inner diameter" (is that english :oops: :lol: ), and that's why they appear smaller.
If you look at the area between the bobbins
Going from the gold inner ring to the start of the stainless outer to me that looks a bigger gap in the ZXR discs.......dontcha think :?
Post by alimorg »
I am pretty sure that the ZXR250 used the same calipers as the KR-1, not the KR-1s so the smaller swept area is probably due to that, as for the gap yes it does look bigger.
AL
Cheers Al do you think they will fit the Kr1S set up then?
If not any one want to buy some KR1 discs :lol:
Post by alimorg »
Yes no problem on a KR-1S, but they are too big for a KR-1 (280mm discs you see!) ZXR has KR-1S discs with KR-1 calipers!
AL
Cheers Al
All is cystal clear now :wink:
alanw
Post by alanw »
jan bros,,,,,,,, is right its swept area that makes it look different. If it's not you can cover me in salt & pepper & call me a fish supper :oops:
This must be a northern saying :lol:
Are you saying you are pretty sure but not 100% sure and don't hold you to account :lol:
If the KR1S brake pads bite over a larger area would this still be fine to use if they run a bit over the inside edge of the stainless outer?
I mean wavy discs have this happen don't they?
O.k. i'm outta my depth here so anymore for anymore (advice) :D
alanw
Post by alanw »
I'v blown the pic up .From what I can see these disks "look" to have been used with the wrong pads (to small) :?: . But they sure look like KR1S.
Red Devil 777
EBC replacement discs for ZXR250A
http://www.brakes4u.co.uk/products.asp?id=2647
md4008
EBC replacement discs for KR1S
http://www.brakes4u.co.uk/products.asp?id=2635
md4008
I've got both and the only difference is that the zxr ones are bolloxed :lol:
All the other posts are correct zxr250 has same caliper as a 1 so maybe the swept area bit is correct. Anyway I've got 1s discs on a zxr 250 wheel with kr1s calipers fitted to zxr400h fork legs and it all works.
Plus if you check the pads out you'll see that the zxr ones are all fa141 which is the same as the KR1S rear, which also shares it's pads with the KR1 fronts....phew.
I love you all :lol:
alanw
Post by alanw »
Headcoats Red devil knows nothing about Football......... :lol: But you can trust him on "front forks, disks caliper conversions :wink:
