Gaskets, advice please.
Posted: Tue Aug 07, 2007 7:42 pm
by Bikemike
When I took the barrels off the Graham File tuned engine in the Garden project no kind of gasket sealant appeared to be used.
Now I figure that if Graham doesn't use a sealant then you probably don't need one..but I seem to recall reading on here that you should.
So I'm confused :?
Can anyone help me out on this one?
Mike
Posted: Tue Aug 07, 2007 8:31 pm
by Cliff
I have never used sealant on base gaskets, i'm not sure it's needed either, it seems overkill to me. Plus it's a pig to clean off, save it for Austin Metro's :lol: .
Posted: Tue Aug 07, 2007 8:51 pm
by rc46
basically what cliff said, you shouldnt need a sealant, on the base gasket i used a little as others have said that the front of the gasket can move, and the sealant helps keep it there, BDK didnt see the point, i just did it to be sure, I used hermitite (i think thats it) but its a bugger to work with, i would think if you just make sure both surfaces are as clean as you can get you should be fine.
Posted: Tue Aug 07, 2007 10:00 pm
by Bikemike
Cheers Guys,
I was hoping the answer would be don't use any :)
Mike
Posted: Thu Aug 09, 2007 10:53 am
by the-elf
I alaways use a sealant on the base gaskets as they can move forward and empty the contents of the rad down the front of the engine. Both MJ and I had this happen last year.
