Could someone kindly measure their brackets for me please... The two that bolt onto the frame above the engine... They hold the top fairing in place...
Mine are pretty mangled and I need to get some more made up... From what I can work out, they're 75mm from tip to tip...
But, after comfirmation before I start fabricating something...
Also, it seems I need to make 4 spacers (8 mm thick) to keep the front mudguard off the front tyre... Is this normal or do I have a weird mudguard???
Cheers in advance
Nate
