will steering damper from other bikes fit?
Post by Charles »
Hi,
I am looking for a steering damper for my KR1-S. As I sofar have not been able to trace an original one, do steering dampers from other Kwaks fit?
thanks!
Yep mine is just a standard ohlins damper, with a standard fork leg clamp and standard ohlins mounting kit.Not that ohlins actual make them asa kit to fit the KR but they do make the actual parts that you need.
