Carbs - Why am I so confused
Posted: Sat Dec 22, 2007 4:30 pm
Hi Gang... Merry Xmas and all that jazz
Following on from my "petrol in my pipes" post...
I have removed my RHS carb to try and identify the problem with this over fueling to the RS cylinder and exhaust...
Ok, the thing is I have no idea what I am doing when it comes to carb settings...
This is what I have done
a) Taken float bowl off, tried blowing though the petrol inlet and flicking the float up and down... The float and hence the valve works a treat and wont let air through, therefore I can assume it wont let petrol through either...
b) after a bit of metal work, I have clamped the offending carb to the bench and have got the petrol tank set up above it...
My thinking is that if the float is out of adjustment, if I leave the petrol on, fuel should leak out from somewhere... Anyway none comes out
so
c) looking in the manual, it bangs on about a fuel height guage (which seems to me to be a clear tube that I can measure the head of pressure with (I guess))..
So, where do I plug this clear tube on??? At the bottom of my carb I have two outlets...
a) being my carb drain / overflow
b) being another one
I have tried plugging the tube on to option b but nothing comes out
I have tried plgging it on to a (i.e. the drain one) and petrol comes out if i undo the drain allen key thingy...
I this the right way to go or am I just being a twit [-o<
I guess if someone could explain what I am trying to achieve and how to do it, that would be great... If you could use words of one or two sylables as I think I am being a bit dim here on this one
Nate
so
Nate
