Hey all,
Many thanks for all the comments on the Carb set up... My carbs are luvly Jubbly now...
Handy hints are
1) Coke Cola - Makes for a fantastic Varnish remover... Just soak all your bits in Coke for a few hours and they clean up really nice
2) Air line helps blow everything out
3) Take your time and work in a clean environment
Anyhow, my question now is....
My RHS cylinder seems to warm up a lot quicker than my LHS... tempreture difference is noticeable right the way up to the cans...
Now, same idle jets, same leaness of mix, same plugs etc...
Anyone any ideas? or is it just the way it is?
cheers
Nath
RHS hotter than LHS
- nate
Think you might find its your carb balance Have you set the tickover as per the manual Think you set one carb tickover first then balance the other one up to the same speed. Then again i'm no expert i,m sure someone else might have another explanation.
Could be a few other things a swell as the carbs. A internal water leak into the cylinders/cases, a intermittent spark caused by a failing HT lead or plug.
- nate
ooooh I prefer Flutes idea Sounds a lot less expensive [-o<
Will check the carb tick over adjustments tomorrow...
Elf, cheers bud... Luckily I replaced plugs and HT side when I rebuilt it... So possibly a coolant leak but the oil is clear and no loss of fluid...
Need to start stripping down the spare engine anyway, so will check that one!!!
Thanks
Thanks
- nate
cheers Jiffi,
The tick over adjustment cured it... I just forgot to do it and so tweaked the RHS carb up to get the idle right
good thinking though.... so I might have it running a little more on the LHS side as the temp's are even.... Next time the carbs come of I will have a nose at the idle adjustment and report back
