Dimension Please ? Urgent
Posted: Fri Mar 14, 2008 9:12 am
by NOS EXUP
Hi
Can anyone please urgently give me a dimension from outside disc face to outside disc face on a KR1S - I am overseas (Sweden)at the moment and urgently need this dimension for a company over here.
The measurement needs to be across the outside of the front disc rotors.(ie across the front wheel left to right) please state if discs are standard or aftermarket although this may only affect slightly due to disc rim thickness.
Cant leave it up to my wife to measure mine back home
thanks
Nick
Posted: Fri Mar 14, 2008 12:43 pm
by nate
Ok, this is what your after...
From the outside of one to the outside of the other
126.12 mm
or 125.92 mm
I measured at the top and the bottom to allow for warpage and floatiness of disc...
Hope this helps
Oh and standard disks, plenty of meat left on em
Posted: Fri Mar 14, 2008 1:03 pm
by Red Devil 777
I've just checked two front wheels for you, unfortunately neither are 1s,
zxr250 is 126.0mm
kr1 is 125.5mm
Both outside edge to outside edge
Hopefully this concurs with Nates figures
zxr is std 1s discs
kr1 are aftermarket but not 100% certain what variety.
Posted: Fri Mar 14, 2008 1:21 pm
by NOS EXUP
THANKS GUYS
I WILL TAKE IT AS 126mm
THANKS FOR THE FAST RESPONSE
=D> =D> =D> =D> =D> =D> =D> =D> =D> =D>
Posted: Fri Mar 14, 2008 1:27 pm
by nate
No worries...
My neighbours must think I'm mad... I have a meeting to go to in a bit, so I'm in a pinstripe suit.. measuring the discs on my bike, then walking around holding a digital caliper
Happy days
Posted: Fri Mar 14, 2008 1:37 pm
by NOS EXUP
Posted: Fri Mar 14, 2008 2:11 pm
by the-elf
If its a problem then why not fit a dufferent wheel and yokes as well? I think a pair of dymags would go nice with those forks
Posted: Fri Mar 14, 2008 2:27 pm
by NOS EXUP
Hi Elf
making my own yokes but want to keep the KR front wheel and retain speedo drive as per KR1S.
I am trying to retain the KR1S look but with a few replacement high end parts to have the ultimate well engineered KR1S.
I want to keep the matching KR1S wheels - i have looked at Marvic , Dymag routes in matched pairs but then i would have to look at 17" rear and brake / sprocket issues. Also magnesium wheels can only be painted and not sucessfully powdercoated and this is my preferred surface finish for wheels.
Trying not to detract too far from the KR1S original look.
It involves lots of machining time with any modification away from standard and when building a special i always say go with what you like in terms of quality , function and appearance and obviously price comes into it somewhere.
cheers
Posted: Mon Mar 17, 2008 9:12 pm
by the-elf
My bike used to have an RGV 17" rear 3 spoke and a modified ZXR400 3 spoke front in the standard yokes and forks. Since then I fitted the ZXR400 modified SP front end and a 17" 5" wide Dymag rear wheel. I later fitted a comple RGV rear end. Each to their own though
as Dymags etc are very expensive.
