Crankshaft seals
Posted: Tue Sep 26, 2006 2:16 pm
Hi folks.
After reading horror stories of crankshaft seals going, and my bike sitting un-run for way too long, I am going to change them as a precaution.
Just about to split the crank cases, but I've not seen an engine like this before - a couple of things confuse me ;-
1 How does the primary gear come off ?
2 If the balancer shaft runs in gear oil - are there crank seals on the inside as well, ie 4 all together ?
3 Do you have to get the crank re-built in order to replace the seals ?
Everything else I've had only has a seal at either end.
Another good reason for changing them is I found the missing piece of this clutch plate thing floating around in the gearbox.........very chewed up.
Thanks,
Tambo
Thanks,
Tambo
