carbs info
Posted: Sat Apr 12, 2008 9:27 pm
by buzinc
Hi Guys. Need some carb info. Looked at the manual but dont help
My two stroke knowledge is yam aircooled, this is my first kwack.
Removing the carbs, the L/H and R/H carbs have the float bowl drains on the inside, ie facing each other. Is this correct?
Also why does the R/H have bowden cable to adjust the idle and the L/H usual screw you cant really get at?
Also where to purchase main jets etc.
Also the airfilter foam element - I have a large piece of foam from a sofa! is the oem still available?
Buz
Posted: Sat Apr 12, 2008 9:47 pm
by martin
yes the drain screws are on the inside and the left carb has only the screw that you say, some people get another right side one to make adjusting easier, try allens performance [do a google search] thats where i got my bits from
Posted: Sun Apr 13, 2008 7:28 am
by mr_bungholeo
sean does a very nice pipecross filter on his site... http://www.thetuningworks.com ive bought two...very good..better than standard \:D/
Posted: Sun Apr 13, 2008 9:54 am
by buzinc
Just had a look at seans site, is it a direct replacement of the kr1 foam element that fits in the air box. Did u have to up jet, if so what sizes
buz
Posted: Sun Apr 13, 2008 12:58 pm
by the-elf
The filter is a straight swap.
