clutch removal
Posted: Tue Apr 22, 2008 6:01 pm
by buzinc
Dopy question. How do you remove the clutch basket. I have removed the outer cover, 6 hex screws, springs friction plates etc. Tried to pull it off with ones fingers, but it aint moving. What have i missed?
Posted: Tue Apr 22, 2008 6:18 pm
by mr_bungholeo
if you've removed the springs and the flower shaped bit of ali they screw down on..behind it on the shaft in the center is a circlip.... :D
Posted: Tue Apr 22, 2008 7:09 pm
by mj43
Removal process
unbolt cover - carefully jiggle it off you should be able to save the gasket - I use the clutch release mechanism to help get it off the dowels.
If you don't want to get at the clutch plates then remove them as a whole without undoing the 5 bolts.
Pull centre part out of the clutch which will reveal a circlip. Take this off and the plates will come out as a complete assembly.
remove the large washer - it is splined so align it propely on the shaft. Now you can pull the clutch drum out. Behind this is a washer and another circlip. Washer some time sticks to the clutch drum.
Assemble in reverse order.
Posted: Tue Apr 22, 2008 11:16 pm
by buzinc
cheers guys. Still couldn't get basket off. Had to remove R/H case. This enabled me to get fingers behind the basket to pull it off.
Still didn't ease off very well. Almost looks like the phosphor bronze bush was too tight a fit. Couldn't see any scoring or heat damage to bearing through.
Also the magneto bolt, left or right hand removal? :oops:
Posted: Wed Apr 23, 2008 9:11 am
by nate
left hand thread... I think the dimensions are postd in the KR Kive somewhere!!!
