Swingarm Needle bearing removal advice
Posted: Thu Dec 04, 2008 3:02 pm
by headcoats
I'm getting the swinger powdercoated soon ,so need to get the bearings out.
How the bloody hell do you do it ?
Also how do you put the bloody things back in
Shall i put new ones in ?
Posted: Thu Dec 04, 2008 3:59 pm
by the-elf
A piece of steel tube with a slightly bigger internal dia and a bar to push them out, and press them out in a vice or a press. Two man job but it works. Had to do my old KDX220 when they collasped, and they were seized in solid. This was the only way we could get them to budge.
Plus its such a PITA job I would always put new one back in, complete with any new seals etc. On mine I had to replace the spacers and the shaft as well due to the wear.
Posted: Thu Dec 04, 2008 4:19 pm
by scooble
got mine out by heating the swinger with a heat gun and using a long drift to punch them out. They were knackered though so I wasn't too concerned about damaging the bearings.
To get new ones back in, I used the swingarm pivot bolt and some cylindrical spacers that were the slightly bigger in diameter than the bearings. Place the pivot bolt nut on the other end (also with spacers) and wind both of them in with a ratchet. Use lots of grease though and a bit of heat (espescially to get it started).
maybe not the best way, but it worked for me
Posted: Thu Dec 04, 2008 5:09 pm
by Red Devil 777
Stick new bearings in the freezer for a while, they'll go in a fraction easier.
I normally use a length of threaded rod with a plate on one end, and a socket about the same size as the bearing, large washer or two over that, nut on top, then ring spanner on that and wind it in.
Make sure you don't damage the place where the bearing will sit with a drift when removing them
(not saying any more
Can't remember if you can get generic bearings for the swingarm, but might be worth checking out with a decent bearings factor before paying for the same thing in a little kwak packet
Posted: Thu Dec 04, 2008 5:34 pm
by headcoats
Cheers for the replies
Just getting the first one out looks the biggest headache
Elf do you mean pushing the one all the way through with a bar as in say the right bearing would exit on the left
Posted: Thu Dec 04, 2008 6:31 pm
by Red Devil 777
headcoats wrote:Cheers for the replies
Wouldn't try it that way, most swingarms have an internal stop (can't remember if the kr arm does or not, lost track now
) for the bearing to sit on , so you'll be messing for a long time
In extreme cases, where they've been rusted in , I've even used a dremmel with a slitting disc to cut the bearing before getting it out, hopefully yours shouldn't be as bad as that!
Posted: Thu Dec 04, 2008 6:45 pm
by SHimmer45
there is an internal ridge...
when i did mine (with some help) i got the bearing started and then pulled it in using a bot of threaded bar and the blanking plates i used to cover the holes.
slowly tighten one end and it pulls it in nice and flat
if any ones got bearing numbers ile look
Posted: Fri Dec 05, 2008 9:36 pm
by fred
Can't remember if you can get generic bearings for the swingarm, but might be worth checking out with a decent bearings factor before paying for the same thing in a little kwak packet ,
ime stripping mine for powdercoating at crimbo holliday and am ordering bits now,
Posted: Fri Dec 05, 2008 10:59 pm
by Steely
Posted: Sat Dec 06, 2008 12:24 am
by SHimmer45
when i wassourcing bearings from a bearing factor the swingarm and suspension linkages had to be geniune kwak as they are an odd size, cos they are very wide
Posted: Sun Dec 07, 2008 12:05 am
by kwackman12
If someone could send me an old set of bearings or dimensions I could try the bearing factors near me
Posted: Sun Dec 07, 2008 11:22 am
by the-elf
Red Devil 777 wrote:Stick new bearings in the freezer for a while, they'll go in a fraction easier.
Dry ice in alcohol works well
you can get them done to -50 quite easily
Posted: Sun Dec 07, 2008 11:28 am
by the-elf
Nope push the right one out of the right side and the left out of the left side. It'll depend on the design of the arm as to the best way to push them out.
Posted: Sun Dec 07, 2008 12:20 pm
by SHimmer45
kwackman12 wrote:If someone could send me an old set of bearings or dimensions I could try the bearing factors near me
i can sort some dimensions out for you
Posted: Sun Dec 07, 2008 1:45 pm
by Red Devil 777
Bearing is listed as bm283417 on the parts list (care of mj's website
So I assume that to be 28mm bore, 34 mm outside diameter, 17mm width.
Quick search shows it's not a common size but there are some available.
Also smaller bearing on the linkage is definately available from non kwak sources cos I've had some.
