zxr forks diffrences
Posted: Tue Apr 07, 2009 5:49 pm
by mgtkr1
just got some maxton zxr forks but has a leaky seal. there h model forks, is there any diffrence between h1/h2 nodel forks(usd). also are all zxr forks multi adjustable or just sp. and last but not least are kr1s calipers a straight bolt on? thanks all guys.
Posted: Tue Apr 07, 2009 7:36 pm
by the-elf
H1/2 forks are the same L are different internals and I know the fork seals are different between the H and the L. Only the SP have the bottom
compression adjuster and are like rocking horse manure. KR1s Calipers are a straight bolt on jobbie as are SV1000 and several others. The SV have the same type but are a leter design and offer a good up grade over the KR1S calipers.
Posted: Tue Apr 07, 2009 11:08 pm
by mgtkr1
thanks kev, re kr1s calipers thought so but thought best to make sure. re sv1000 calipers, they a straight bolt on aswell? no need for top hat bushes? what are the std zxr fork like for adjustment? just preload or do they have rebound damping aswell? anyway thanks for the info as ever kev, oh if you find some clip ons let us know and ill send you some p+p and beer tokens. al;so buy you a pint or 2 when we get together. cheers matt
Posted: Tue Apr 07, 2009 11:52 pm
rebound adjustment to on all ZXR's
Posted: Wed Apr 08, 2009 7:32 am
by alanw
MG the calipers will bolt straight on to the forks but depends on the which yokes you use & which wheel for width spacing. zxr h yokes with zxr h forks & Kr1s wheel = 5mm spacers between caliper & its mount + new
spindle & spacers Alan
Posted: Wed Apr 08, 2009 5:14 pm
by mgtkr1
ok, so comp h model zxr front end will work with kr1s calipers? thanks fellas
