bad starting
Posted: Sun Nov 05, 2006 5:39 pm
by rockerted
any ideas..hard to start, eventually does fire up,leave a couple of hous go back and fires second kick usually..good spark..petrol seems to get through..goes well once running,but sometimes ticks over at 3000, and eventually drops back to 1k
Posted: Sun Nov 05, 2006 6:27 pm
by Tambo
Sounds like an air leak. Perished carb rubbers , or vaccum hose ??
Other than that, perhaps a sticky carb slide, but that normally makes the revs rise much more.
Let me know how you get on.
Good luck !!
poor starting
Posted: Sun Nov 05, 2006 9:13 pm
by sprocket stu
we have changed the vacuum pipe as it wasnt sealing very well and the next step is the inlet rubbers
Posted: Sun Nov 05, 2006 9:44 pm
by Garry
try petrol tap in prime position and see if that makes
a difference
Posted: Sun Nov 05, 2006 11:18 pm
by LEE MAFFS
Sounds like carb rubbers air leak or throttle cable sticking?>
post
Posted: Sat Nov 11, 2006 5:18 pm
by rockerted
Posted: Sat Nov 11, 2006 7:42 pm
by Tambo
Nice one !!
Satisfying to get a result
before there's an expensive bang
poor starting
Posted: Sun Nov 12, 2006 11:04 am
by sprocket stu
also turned oil pump down as it was over oiling i think it may need a hotter set of plugs now the weather has turned it is only getting used for shortish runs ( like most of them at this time of year)
my old gt380 used like hotter plugs in the winter to prevent them fouling up
