Time for some tlc on mine
Re: Time for some tlc on mine
Post by fred » Thu Jan 03, 2019 11:33 pm
i can only find single lip seals . i will order some jb weld and i can etch the shafts so it sticks well , and thought i would try sealed bearings and sort 2 problems out , 8mm id x 14mm os x 4mm wide ,more surface area to stop everything rattling about ,hopefully .£10 for 10,we will see. ile have a look tomorrow to see if there is enough meat to counter bore into the seats to have a bearing and seal
c&c
Post by c&c » Fri Jan 04, 2019 3:44 pm
Did you get the barrels replated.?
I had a chance to be insane , asylum from the pouring rain..
Post by fred » Fri Jan 04, 2019 4:26 pm
These are good barrels I bought off Alex Hutchinson years ago. I must have 4 pairs of matching barrels to send off to poeton aptec to get repaired and plated, but not yet,
Just bought some Power Maxed steel epoxy to repair the wear on the kips valves. See how it goes.
And just posting a lower exhaust bracket off to a Andrew Lewis that did Bonnerville on his Kr. Will have a read up on that later. Cheers
Post by fred » Sun Jan 06, 2019 9:53 pm
Let's see how this goes
Post by 500bernie » Sun Jan 06, 2019 11:38 pm
Nice work Fred, looking forward to seeing the finished product.
Bernie 8)
Post by KR-1R » Sun Jan 06, 2019 11:51 pm
the KIPS oil seal (92049-1238) is still available from Kawasaki ¥500 each - about £3.30 :shock:
common with the KX85 apparently
http://www.kawasaki-motors.com/for_user ... g/Estimate
probably why you are looking to improve robustness and save money at same time - if the finished tolerance on the stems is close enough, would you even need seals on top of sealed bearings?
If this forum is valuable to you - then stop diluting it by posting on F A C E book :idea: Find an answer on this forum to any FB requests and link them to that
Post by fred » Mon Jan 07, 2019 12:00 am
That's my thinking. Mine have always danced and bounced about a bit
Post by fred » Mon Jan 07, 2019 8:29 pm
They fit sound. I'm going to pop the old rubber seals above the bearing as a damper and to stop the bearing floating. Took up all the sloppiness.
Post by 500bernie » Mon Jan 07, 2019 9:29 pm
A brilliant upgrade Fred 8)
c&c
Post by c&c » Tue Jan 08, 2019 9:05 pm
Clever..🎓🎓
dandan0162
Post by dandan0162 » Wed Jan 16, 2019 12:32 am
Thats a good idea with the valves Fred, I have several that are worn ill give it a try👍do you thi k any oil will be able to escape tho?, let me know how they perform cheers dan
Post by fred » Wed Jan 16, 2019 12:40 am
I'll use a little Heldite sealer (used for petrol and diesel sealing over ptfe pipe joints) around the stem and on the outer race. I will pop the old seal above just as a damper, on a spare head I need to tig weld a snapped ring Mark up in the squish area so will remove the steel sleeves and counter bore in 3mm so a bearing and seal will properly fit. But that's a way off yet
Users browsing this forum: No registered users and 5 guests
