shut your PIpE hole
The Place for archived technical posts, the KR-1 Manual, the KR-1S suppliment and parts lists.
shut your PIpE hole
Post by KR-1R » Tue Jan 08, 2019 10:15 pm
A gallery of the different pipes/chambers
if you have some photos of your exhaust or better when fitted, post them up
to see all the options
Jolly Moto
Good Luck With Racing £748 + vat
http://www.jollymoto.it/
https://www.pjme.co.uk/acatalog/Kawasak ... austs.html
courtesy: Martin/500Bernie
If this forum is valuable to you - then stop diluting it by posting on F A C E book :idea: Find an answer on this forum to any FB requests and link them to that
Re: shut your PIpE hole
Post by KR-1R » Tue Jan 08, 2019 10:16 pm
Kawasaki Kit SP/F-3 chambers
Type 1
photo courtesy: Kopite30 & Podman
JL - Jim Lomas pipes
Post by KR-1R » Tue Jan 08, 2019 10:22 pm
JL - Jim Lomas
mild or stainless with stainless, carbon or Kevlar muffler/silencer options
by far the most popular KR chambers
warning: fitment problems of fairing belly pan, can also be tricky to seal oil leaks, and possibly chain rub
modifying the bellypan...
photos courtesy: 500Bernie
photos courtesy: SP_BOTT
photos courtesy: MACCAS
Czech-ing Out JL Exhausts - Jim Lomas pipes <<< PDF
K2 Tec expansion chambers Japan
Post by KR-1R » Tue Jan 08, 2019 10:37 pm
K2 Tec Japan
http://k2tec.cart.fc2.com/ca94/268/
http:/japan.webike.net/
various types - there are different options/headers/stainless etc
Type 1 cheapest... mild steel, basic rolled tube header ¥45,360
Type 2... lobster headers and elaborate belly ¥90,720 mild, ¥113,400 304 stainless, ¥124,200 mirror polished
Post by Binetta Steve » Tue Jan 08, 2019 10:43 pm
Pure welding art and craftsmanship, thanks for sharing.
LOONY chambers Japan
Post by KR-1R » Tue Jan 08, 2019 10:52 pm
Exhaust by Tony Green
Post by KR-1R » Wed Jan 09, 2019 2:04 am
Post by KR-1R » Wed Jan 09, 2019 2:56 am
Exhaust by FRED and LUDERS
Project KR-2Image
Exhaust by FRED
hurry up already
podman
Post by podman » Wed Jan 09, 2019 9:40 am
Hard to pick a favourite out of those but I think the Jolly Moto's edge it for me...Not overly impressed with the finish / manufacture on my JL cans and they needed a small amount of filing to get them to fit the chambers...
Post by 500bernie » Wed Jan 09, 2019 10:16 am
I have had Nikkon and Lomas pipes, I liked the quality and finish of the Lomas pipes better (and the header spring mounts were x10 better on the Lomas pipes).
I never checked the internal finish of the headers, that's another item on the todo list.
Post by JanBros » Thu Jan 10, 2019 11:18 pm
EXHAUSTS OF JANBROS :
copies made on the outside of originals, by spotwelding plates on the joint and hammering them into the correct form, then cut them lose and weld the 2 halves together. Diameter is slightly bigger, but you lose the thickness of the joint, so all-in-all, shape and volume are about the same.
main difference : 2 copies weigh less than 1 original, and the sound is what it always should have been : sharper and with a "metalic touch" .
Never felt any difference in power compared to originals, so maybe this is THE best solution for weight and power, appart from the look which of course is beaten big time by Lomas etc...
Post by 500bernie » Thu Jan 10, 2019 11:52 pm
As usual some great work again by you Jan 8)
Users browsing this forum: No registered users and 0 guests
