remote carb idle screw
Posted: Fri Apr 26, 2019 12:53 pm
Has anyone improvised or found a source of for the remote idle screw on the right hand carb?
Maybe other carbs / bikes use the same part? I've done a bit of a Google and found parts that might be compatible, but looks like it would be guesswork
Mine seems to have been broken off at some point, though it screws in and out OK, raising the slide as expected.
Worst case was thinking just push a small piece of plastic tube over the end, but would prefer a "proper" part if they can be found anywhere
