Page 1 of 2
Shorter dogbone links for increased ride height.
Posted: Sat Apr 08, 2023 5:53 pm
by MarkW1966
Hi guys.
Still yet to decide between a Maxton or Nitron rear shock but I know I will need to increase the ride height.
I know BDK do shorter links but is there a standard Kawasaki replacement from another bike?
Thank you for any advice.
Mark.
Re: Shorter dogbone links for increased ride height.
Posted: Sun Apr 09, 2023 8:32 am
if you are going to put another shock in, why also other dog bones?
just put a slightly longer shock in, or better one that can be adjusted in length.
Posted: Sun Apr 09, 2023 9:59 am
by MarkW1966
I'm looking to replace the original with a Maxton or Nitron unit.
Neither of these offer longer or ride height adjustable shocks.
I understand an R6 unit can be made to fit but finding a good one is proving difficult.
Posted: Sun Apr 09, 2023 11:46 am
you need to make adjustments to the airbox to fit an R6 shock. and it is too long in my view.
think I still have one lying arround somewhere on my attic. for sale if you want it (not after big money), mind you : shipping needs to be done from Belgium.
I opted for this solution :
viewtopic.php?t=2579
nitro does one for them, with adjustable length. you just have to swap the "eye" at the bottom for a "U" , I'm pretty sure Nitro can do that.
Posted: Sun Apr 09, 2023 6:04 pm
by MarkW1966
Hi Jan.
I would be interested in the spare R6 shock if it’s a good one.
I’m aiming to run without an airbox so that’s not an issue.
Thank you.
Mark.
Posted: Sun Apr 09, 2023 9:51 pm
I'll have a look tomorrow.
I bought it second hand, looks as new. I have only try-fitted it, never used it. will try to dig it up tomorrow and post a pic.
Posted: Mon Apr 10, 2023 7:52 am
by MarkW1966
Thank you
Posted: Tue Apr 11, 2023 10:40 pm
sorry, keep forgetting it
Posted: Wed Apr 12, 2023 9:02 am
by MarkW1966
No worries Jan. Whenever you are ready.
Mark.
Posted: Wed Apr 12, 2023 11:52 pm
60 euro ?
thinck it's 2006-2007 ? definitly pre 2009 as I posted pics of it that year on the forum.
post should be 14.90 if it's under 2kg total, 34.60 if it's above.
Posted: Thu Apr 13, 2023 8:19 am
by SP_BOTT
That's the one I fitted to mine, had to make a few shims and sleeves, but it was on a KR-1 not an S.
Posted: Thu Apr 13, 2023 1:20 pm
by MarkW1966
How do you rate the R6 shock?
Obviously it's a saving of over £500 compared to an aftermarket Maxton or Nitron) one.
Mark.
Posted: Fri Apr 14, 2023 1:18 pm
by SP_BOTT
Sorry not ridden it, only wheeled it in and around the shed, it bounces ok, doesn't look much higher than standard to be fair. Can get a couple of measurements if you want, but for £75ish must be worth a punt, can always flog it on if you're not happy. Don't think the spring is much fatter, but it's very close to the swingarm. I always thought the standard shock mount on the frame should be longer, so the shock would be more vertical.
Posted: Sat Apr 29, 2023 5:44 pm
@ Mark, do you want it or do I put it back on my attic ?
Posted: Sun Apr 30, 2023 10:10 pm
by MarkW1966
Hi Jan.
Still not sure which route to go down.
Maxton will build me a shock with an extra Inch in length so might just get one of them.
