Brake bleeding Issues
Posted: Tue Jun 23, 2009 12:15 pm
by Jiffi77
I've now got one of the syringe kits recomended (nice piece of kit), when bleeding the left hand caliper I get a constant stream of air in the pipe regardless of how many times I repeat the process. Is it possible that air is being drawn through the threads of the bleed nipple (the bleed nipple does seem to be a loose fit) ?
The brakes do feel better since using the syringe but not as solid as they should be.
Posted: Tue Jun 23, 2009 2:10 pm
by ScottaKR
Yes, what you describe is not only possible, but apparently somewhat common with this method. Try using some plummers tape (that thin white stuff) around the thread of the bleed nipple to seal it. That seems to be the most common solution.
Posted: Tue Jun 23, 2009 4:13 pm
by Tripitaka
The stuff you need is called PTFE tape and is available at most DIY and all plumbers merchants.
Neil.
Posted: Tue Jun 23, 2009 9:55 pm
that's why I force the fluid in through the bleeding nipple upwards nowadays to the master cylinder, than that problem is solved
you just have to make sure the air is out off the nipple/tube when putting it on (some icking against the hose so the air goes up into the syringe)
Posted: Wed Jun 24, 2009 8:25 am
by Jiffi77
Cheers for your input guys, is the problem likely to be the bleed nipple (they look like standard ones) or the threads in the caliper ?
Posted: Wed Jun 24, 2009 3:40 pm
just put the Teflon tape (PTFE) arrond the treat off the nipple and it'll be ok
Posted: Thu Jun 25, 2009 7:51 am
by headcoats
I had hell of a game bleeding mine and the only thing that worked for me
was tying the lever back and leaving it overnight with the rubber bit removed from the master cylinder and cap just resting on top.
Posted: Sat Jul 11, 2009 5:41 pm
by scooble
I also had problems getting mine to bleed until I fitted one of the radial M/C's with the bleed nipple on top - Sooo much easier than before
