hi,just have a question,well actualy are two
1.-is it possible to fit a rim of cbr 600 f2 to kr1s swing arm?
the original is 130 or 140 i dont remember,the rim that i want to fit to it is 180
2.- can anyone please tell me how to put pictures at this forum?
thanks
kr1s rear wheel
edgar90
The maximum width that'll fit is a 5 or a 5.25" wheel with a 160 tyre although you can squeeze a 160 tyre onto an RGV 4.5" rim. You may also need to adjust the rear brake rod to clear the tyre. a 180 tyre needs a 6" rim and thats way too wide to fit. Plus don't forget you'll need to match up the chain run as well as keep the wheel central.
For photos get an account with photobucket (or simular) and host the photos on there and then use the "img /img" tags to post them on here. There are quite a few posts discriping how its done if you do a bit of a search.
edgar90
You want a 4.5 or a 5" rim but beware a lot of wheels (like the ZXR400)don't match the chain run and would need a new crushdrive and sprocket carrier manufactureing.
Known 17" wheels that will fit are RGV VJ22, Aprilla RS250, Later TZ models with a 5.25" rim (not sure which model though). Also Dymag do some nice ones as well if your feeling very flush
