zxr 400 forks
rvf nut
zxr 400 forks
Post by rvf nut »
Hi there, can anyone put a link up for converting the zxr 400 forks and yolks for the kr1 and what problems come up ,,,,i just bought a complete front end minus 1 caliper and top yolk :D
fail to prepare ,prepare to fail
rvf nut
Post by rvf nut »
just found the forks i bought and looks like the conversion has been done allready [-o<
http://i156.photobucket.com/albums/t12/ ... MG2207.jpg
rvf nut
Post by rvf nut »
just been and had another look at them and it does not look like the spindle has been swapped .I will take a pic then post later.
you can use a H or L yolk, they are ecxactly the same, apart from the hole for the stem on an L model is bigger, bet that can easily be bushed (if you know someone with a lath).
rvf nut
Post by rvf nut »
JanBros wrote:you can use a H or L yolk, they are ecxactly the same, apart from the hole for the stem on an L model is bigger, bet that can easily be bushed (if you know someone with a lath).
I operate a lathe all day mate \:D/
I think they are H1 forks.
rvf nut
Post by rvf nut »
is there much difference between the kr1 and the zxr 400 H1 stem i,e will they go straight in. i just need a top yolk
H stem is just a little bit longer than KR1. don't know how much, 5mm or so. all the rest is the same.
rvf nut
Post by rvf nut »
Nice one i will try it and alter to suit.
spannerman
Post by spannerman »
i run an h front end havn't swopped the stem just shimmed it 5mm as jan says.
ade.
on the pipe!!!
