stuck flywheel
Posted: Tue Feb 09, 2010 10:06 pm
by mick40
Hi all
as the title says i cant get the flywheel to come off.
it seams to be stuck soild tryed a puller and taping it dont know what else to try
any hints/tips or suggestions welcome
cheers
mick
Posted: Tue Feb 09, 2010 10:23 pm
by Tambo
While since I stripped mine, but I remember having to apply more pressure than I wanted to
and it came away with a mighty crack !!
I even made up a 'button' for the end of the crank because I was worried about the puller damaging it - there was so much pressure on it.
Not tried this, but seemingly a few drops of diesel, and leave the engine on it's end for a good day or so. Then try the puller, and if it's not coming, leave it under tension overnight and try again.
Heat would be the answer, but not with the electrics in there
Could try a cloth that's been in boiling water (wrung out) to heat the flywheel while the puller is under tension. Very very last resort would be boiling water, but you're risking damage then !!!
Hope that helps. Good luck !
