keihin slides and parts?
Posted: Thu Sep 16, 2010 2:42 pm
by scooble
I tried to get a pair of Number 6 slides from Allens, however, they are out of stock, does anyone know of any other keihin distributors? (natiional or international)
Posted: Thu Sep 16, 2010 4:57 pm
by dirk
Posted: Thu Sep 16, 2010 7:44 pm
by falconman
I live just a few minutes from Sudco or DG. What carb are you needing the slides for? I can give them a call to see if they have them.
Posted: Thu Sep 16, 2010 8:15 pm
by scooble
I need No6 slides for a set of PWK35's
Posted: Thu Sep 16, 2010 9:17 pm
by falconman
I called all 3 US locations and no one has them in stock. Sorry.
I just looked at the standard jetting list and it shows the 6.0 as stock for the 35. I may have a pair in an old set of 35's (used only once on Sunday at Bonneville '07
). I can check that this weekend when I get home.
Posted: Thu Sep 16, 2010 9:54 pm
by KR-1R
what slide number did your carbs come with?
- the number is either on the top square tab that sticks out or stamped underneath where the needle emerges at the cutaway
standard 35's usually will have #6
Air striker (fins) /quad vents 35's will be #4.5
(if its a 5 or 7 it probably youll need to confirm it is a 35mm body - depends on the donor bike/motor)
BTW - I think a 5mm cutaway will be fine
the different part numbers suggest the airstriker slides wont fit the standard 35s (i will have a measure and photo some 4.5, 5.5, 6.0 and 7.0 slides for you) but I think I have had the AS slides in the std35 no problem
replacing them will be expensive - if you have the smaller number you could machine them 1mm or so to go leaner
this data
isnt strictly correct...
Polaris 700XC 98-99 PWK41? 39?
Polaris 600XC 98-99 PWK39
Kawasaki KX500 88-04 PWK39
h***a CR125R 99-00 PWK38
Kawasaki KX250 88-97 PWK38
Kawasaki KX250 98-07 PWK38
Yamaha YZ250 1996 PWK38
Yamaha YZ250 99-08 PWK38
Kawasaki KX125 92-95 PWK36
Kawasaki KX125 88-91 PWK35
Kawasaki KX125 96-97 PWK35
Kawasaki KDX200 88-06 PWK35
Kawasaki KDX220 97-05 PWK33
h***a CR85R/RB 05-08 PWK28
Kawasaki KX85A PWK28
Kawasaki KX100D PWK28
Yamaha YZ85 93-08 PWK28
Posted: Thu Sep 16, 2010 10:19 pm
by dirk
Posted: Thu Sep 16, 2010 11:16 pm
by KR-1R
that seems like a better price - cheaper than SUDCO list prices
the are some Polaris slides
at even better prices but they are for
#5.5 on the much
bigger carbs
i take it youve checked your kwak dealers price
for part 16025-1164?
recutting slides....
http://www.rb-designs.com/slide-mod.htm
you should be able to butcher some with a drill press - a simple job for someone with a milling machine though
Posted: Fri Sep 17, 2010 7:47 am
by falconman
I was going to suggest cutting the slides. I have done it before (that's how I know a mill is the right way to do it
). Also my friend knows the owner at Sudco and gets a decent discount there.
I was led to believe the air striker is a different slide than the standard, each place asked which model 35 I had.
Posted: Fri Sep 17, 2010 9:26 am
by scooble
by referring to the diagram, is it a simple case of re-cutting the bottom of the slope 1.5mm lower than the K4.5? (assuming that I have a K4.5 - I'll double check that)
Posted: Fri Sep 17, 2010 11:17 am
by KR-1R
YEP its basically the amount revealed in mm
if theyre KDX 35's the slide is usually a number 5
Posted: Fri Sep 17, 2010 5:31 pm
by scooble
actually, I had a look today and found that the slides are in fact No 6, so thats ok, I've already ordered pilots (size 40) and mains from 155 to 160
throttle valve slides for 35mm
Posted: Sun Sep 19, 2010 11:12 am
by KR-1R
thats good news then
Air Striker slide (4.5) and std 35 slide (6.0) ...
both are identical dimensions, but different at the bottom...
standard 35mm is flat on the bottom...
Air Striker (and later slides) are rounded (presumably for lift and flow reasons)...
older slides (OEM) seem to be marked on the top tab (newer on the bottom, where the needle exits)...
the slides from the large body carbs (36, 38, 39, 41) are much bigger than the 35 (33) so are NOT compatible with the 35 ...
