how hard is it to swap the cranks over? HELP!!
Posted: Sat Mar 12, 2011 3:50 pm
by r1guy
Hi All,
Started work on the KR1S this afternoon, what i first thought was just going to be a swap the barrels and pistons over has now progressed into a new conrod required on the right hand cylinder due to it being snapped.....
Am wondering what my options are???
how hard is it to swap the crank over?? do i have to strip the gearbox out aswell????(don't fancey that much.....)
idea's on a postcard please
thanks
Posted: Sat Mar 12, 2011 4:36 pm
by martin
i would do a swap with you with one of the bottom ends i have, plus cash.
and i will even do it for you with a cuppa while you wait :)
by mj43
The KR is the easiest engine I have ever worked on.
I can if pushed get an engine out of the frame strip, replace crank and rebuild, put back in the frame in 2 hours.
Minimum required in the way of tools. Only special tool is an alternator puller.
If you haven't done it before allow a day - just remember no brute force is required if you are having to force something then you are doing it wrong.
Posted: Sat Mar 12, 2011 4:45 pm
by r1guy
martin,
Have sent you a pm mate, sounds like its easy enough then.....
Posted: Sat Mar 12, 2011 5:09 pm
by SP_BOTT
mj43 wrote:The KR is the easiest engine I have ever worked on.
Would you say (if you know) it's easier than an LC/YPVS engine, done loads of these and would be a nice suprise if a later engine was easier to work on?
Posted: Sat Mar 12, 2011 5:27 pm
by martin
drop the bottom end and gaskets off with me and i will strip it and swap the cranks over.
cant do it in 2 hours , but i can do it.
Posted: Sat Mar 12, 2011 6:13 pm
mj43 wrote:The KR is the easiest engine and bike I have ever worked on.
8)
