Page 1 of 2
GOL single ring pistons
Posted: Sun Jul 03, 2011 2:14 pm
by Charles
Hi,
has anyone ever used GOL pistons in their KR1S?
Bought a set of barrels on Ebay germany and they come with 5 brandnew GOL pistons. Found out GOL is a italian piston manufacturer, I had so far never heard of: http://www.pistonigol.com/
Posted: Sun Jul 03, 2011 10:49 pm
by KR-1R
1) The GOL piston is made of aluminium-silicon alloys 18% [AL.SI. 18%). These alloys have a limited
coefficient of thermal expansion able to optimize the assembling between the piston and cylinder to
get the best use at all the temperatures.
2) The pistons' skirt is finished with diamond tools, according to the original form and ovalisation.
3) The normal size indicated on the head of the pistons refers to cylinders with zero tolerance. The
arrow drowned on the piston head shows the way out of the discharged gazes.
4) The piston already has its negative tolerance, which is calculated on the basis of thermal expansion
of the material and in particular on the engine characteristics. During the assembling you should
control that the notch-rings are between the windows of the cylinder.
5) The GOL piston is supplied with normal or special rings, pins and circlips or seeger.
6) The piston pin must be mounted by using slight pressure on it or by heating the piston slightly. Do
not force piston pin entry with hammer or any other tool, since it could cause seizures in the pin hole
or a deformation of the piston.
7) The circlips or seeger must be mounted with special pliers. Be sure that they're perfectly locked in
their side.
8.) All the pistons are submitted to thermal stabilization treatment.
They dont seem to list any for the KR
most likely a Yamaha or Cagiva if 56mm
prices aren't especially cheap either
Posted: Mon Jul 04, 2011 7:03 am
I've had a bit of a look around and found a TZ site that had written a bit about them.
They basically said they were slightly heavier than the standard piston, but this made them more robust.
If they are making racing pistons, I would be interested in knowing what kind you have there Charles and what they are off.
Posted: Mon Jul 04, 2011 7:06 am
by Charles
Hi Ben,
Luders wrote:I've had a bit of a look around and found a TZ site that had written a bit about them.
I haven't received them yet, will post some pics as soon as they will have arrived here. Bought a set of mitakas from BDK too, so can compare them to those.
Posted: Sun Jul 10, 2011 8:23 pm
by Charles
Received the GOL pistons yesterday: they are single ring, otherwise they're identical to the used Mitaka one I got here (haven't received the new ones from BDK yet)
They weigh 164g (incl. ring) compared to 150g (incl rings) of my old mitaka.
Will post some pics tomorrow.
Posted: Sun Jul 10, 2011 8:35 pm
That site was saying they were heavier, but that was a good thing in their opinion.
Posted: Tue Jul 12, 2011 3:44 pm
by Charles
here finally some pics:
What do you think? I think they could be used in the KR1S.
Posted: Tue Jul 12, 2011 4:21 pm
Charles wrote:here finally some pics:
probably yes, but one big problem : seems the deck height is about 1mm less ? so less compression and your squish totaly f*ucked up ...
only usable if with shorter barrels I recon (if you want good power).
Posted: Tue Jul 12, 2011 4:24 pm
by Charles
JanBros wrote: probably yes, but one big problem : seems the deck height is about 1mm less ? so less compression and your squish totaly f*ucked up ...
or a head with adapted inserts...
Posted: Tue Jul 12, 2011 5:08 pm
by Charles
Will measure the difference in deck height as soon as I'll have a new mitaka piston at hand.
Measuring with an old inprecise caliper gives a difference of approx 0-0.1mm.
Posted: Tue Jul 12, 2011 5:30 pm
Charles wrote: Measuring with an old inprecise caliper gives a difference of approx 0-0.1mm.
looks more in the pic's. are the gedgeon-pins at the same height in the pics ?
Posted: Tue Jul 12, 2011 5:35 pm
by Charles
They are the same height. I measured from top of gudgeon pin hole to dome of the piston.
Posted: Tue Jul 12, 2011 6:49 pm
what model are they? I'll try some with my next engine.
Posted: Tue Jul 12, 2011 6:51 pm
by Charles
Hi Ben,
Luders wrote:what model are they? I'll try some with my next engine.
On the box ist just says Kawasaki, no specific model.
If you want to buy a set of mine, you're welcome.
Posted: Tue Jul 12, 2011 7:39 pm
okay Charles, I'll do that
